How Can I Connect My Garmin Edge 840 to My Mac?
Hi everyone,
I recently got the new Garmin Edge 1050, and I’m having some trouble getting my Mac to recognize it as a drive so I can manually transfer files.
What are the methods for transferring files between a Garmin Edge 1050 and macOS? I heard on another forum that people used to use Android File Transfer for MTP devices, but I believe that tool has been discontinued. Will third-party MTP apps like MacDroid actually work with the Edge 1050 on macOS, or are there better ways to handle manual file transfers?
Any advice or experiences from fellow Mac users would be greatly appreciated!
The Edge 1050 doesn’t appear in Finder like older Garmin devices because it uses Media Transfer Protocol (MTP) instead of mounting as a regular USB drive. macOS doesn’t support MTP directly in Finder, so plugging it in won’t create the external drive you may be expecting.
Garmin’s intended option for syncing and firmware updates is Garmin Express. The usual Finder instructions only apply to Garmin devices that mount as standard storage:
  1. Connect the Garmin using a USB cable that supports data transfer.
  2. Open Finder.
  3. Choose Go from the menu bar.
  4. Select Computer.
  5. Open the Garmin drive.
Those steps won’t expose the Edge 1050 directly because it uses MTP. You’ll need Garmin Express or a separate MTP app.
MacDroid is a reasonable choice if you want direct access to the device’s files. It supports MTP, which is what matters here. Android File Transfer used to fill that role, but Google retired it, and it’s no longer a dependable option.
You also have a few alternatives:
  • OpenMTP can browse MTP devices on macOS.
  • For routine use, a cable often isn’t necessary. Ride uploads and GPX routes from services such as Strava or Komoot can usually sync through the Garmin Connect mobile app over Bluetooth. The Edge 1050 can also sync automatically over Wi-Fi once configured.
  • Courses can be sent through Garmin Connect on the web. Connect IQ apps such as Trailforks and Strava Routes can also transfer content to the Edge over Wi-Fi without connecting it to your Mac.
Don’t use Edge 840 instructions for the Edge 1050 because their USB behavior is different. @just_raven is right about MTP, but close Garmin Express before opening MacDroid or another MTP browser since two apps may compete for access. If nothing detects the 1050, try a confirmed data cable first. Many USB-C cables only provide power, which looks exactly like an MTP problem.
Treat this as an Edge 1050 question, not an 840 question. For occasional GPX courses, skip USB and use Garmin Connect’s Send to Device function, then sync over Wi-Fi or Bluetooth. Use MacDroid only when you actually need folder-level access, such as copying files manually, and close Garmin Express first so it does not grab the MTP connection.
Manual access gives you more control, but it also makes it much easier to place a file in the wrong Garmin folder or remove something the device needs. I’d avoid treating the Edge 1050 like a normal external disk, even after an MTP app makes its storage visible.
Pick the method based on the job. For courses, send the GPX through Garmin Connect and sync the Edge by Bluetooth or Wi-Fi. For updates and device management, use Garmin Express. If you need to copy activity files, maps, or other files into a specific folder, then MacDroid or OpenMTP is the appropriate route because Finder cannot browse the 1050’s MTP storage.
Before connecting, quit Garmin Express completely, use a known data-capable cable, and copy files rather than moving the originals. Let the transfer finish before unplugging. The “Garmin drive in Finder” instructions apply to the Edge 840 and older mass-storage models, not the 1050.
Don’t delete anything from the device the first time you browse it over MTP. That’s the real trap here, not the connection method. Once an MTP app shows you the folders, it’s tempting to tidy up, and half the stuff with cryptic names is exactly what the Edge needs to boot properly.
@signal.dev already nailed the sorting-by-task logic, so I won’t rehash it. The bit everyone keeps circling but not saying plainly: for 95% of what people actually want, you never need the Mac at all. Wi-Fi sync plus Send to Device covers courses, updates, and activity uploads on its own.
MacDroid or OpenMTP earns its place only when you’re pulling files off, like grabbing a raw FIT file for analysis or backing up your maps before a firmware update. Fine tools for that narrow job. Just don’t reach for them as your default workflow, because you’re adding cable fiddling and folder risk to solve a problem Bluetooth already handles.
Installing an MTP app just to retrieve a ride creates more work than it solves. If the activity already synced, open it on the Garmin Connect website and choose Export Original to download the FIT file straight to your Mac.
Use MacDroid or OpenMTP only for files that never synced, maps, or folder-level work. Finder is a dead end with the Edge 1050 because macOS has limited MTP support.
And fix the topic title. Edge 840 instructions will keep attracting answers that do not apply to the 1050.
Don’t pay for an MTP app before deciding whether this is a one-time transfer. If you only need to recover an unsynced FIT file or copy a large map, borrowing a Windows PC is often the least annoying workaround. Windows can browse the Edge 1050 as a portable MTP device without extra software, although it may not receive a normal drive letter. Garmin’s manual confirms that macOS does not detect it by default while Windows handles it as a portable device or removable storage.
For regular Mac access, I’d try the free OpenMTP route before MacDroid. Quit Garmin Express, connect the 1050 with a known data cable, unlock or wake the Edge, and then launch the MTP program. Connect directly to the Mac rather than through a monitor, dock, or cheap USB hub. Those intermediaries can charge the device while quietly failing at data transfer, which sends you looking for a software fix to a hardware problem.
I’m less convinced that Garmin Express counts as a useful answer for manual transfers. It is fine for updates, registration, and Garmin-managed content, but it does not turn the 1050 into a normal Finder volume. If your goal is simply getting a course onto the unit, Garmin Connect is cleaner. If your goal is browsing folders, Express is not a substitute for an actual MTP browser.
The title really does matter here. An Edge 840 and an Edge 1050 can behave differently when attached to a Mac, so anyone finding this later should confirm the exact model before following Finder instructions. For the 1050, expect MTP, not a Garmin disk on the desktop.
Don’t copy a GPX into the Activities folder just because it looks like the obvious destination. For a manual course transfer on the Edge 1050, the usual process is:
  1. Quit Garmin Express.
  2. Connect with a data-capable USB cable.
  3. Open the device through MacDroid or OpenMTP.
  4. Copy the GPX, TCX, or FIT file into Garmin/NewFiles.
  5. Wait for the transfer to finish, disconnect, then let the Edge import it.
The file may disappear from NewFiles after import, which is normal. The finished course should appear in the device’s course list rather than remain there as a loose file.
For anything already available in Garmin Connect, “Send to Device” is still the simpler route. Manual MTP access makes sense when a file will not sync or you specifically need to retrieve something from the device. And yes, the title should say Edge 1050, since Edge 840 Finder instructions send this in the wrong direction.
