How Well Does Muse AI Handle Languages Other Than English?
I’m correcting Spanish transcripts in Muse AI for my team’s training recordings, and it’s taking more cleanup than I expected. The English sections look usable, but the Spanish sections keep losing little connecting words, even when I can hear them clearly. Searching for phrases I remember from the recording has been frustrating too.
Are others seeing this difference between languages? Our speakers sometimes switch between Spanish and English; does it happen on recordings that stay entirely in Spanish?
A Spanish-only excerpt versus that same passage inside a bilingual recording would be a useful comparison. I wouldn’t assume the language switches explain everything. Try transcribing the excerpt separately and check whether the same connecting words disappear. That won’t establish how Muse handles Spanish overall, but it should help narrow down your cleanup problem. For searching, try a distinctive noun or technical term instead of the whole phrase. If search relies on the transcript, those missing words could be making a clearly audible sentence difficult to find.
Missing connectors can lead to misinterpretation of the statements. For instance, in the training material if any of the “si” is omitted, it might create an impression of an unconditional statement. I would consider Muse’s Spanish statements as a draft for my recordings even if some parts of the sentences sound complete. Correcting the obvious mistakes will not make me feel confident about the accuracy of the entire material.
@quantumlab’s comparison could help isolate the cause, but I’d judge whether to keep using it by the review work left afterward. Take a short Spanish section and track how long it takes to make it ready for your team, including listening back, not just typing corrections. If you have to replay every sentence to catch missing words, that’s the workload to plan around. The English results don’t tell you how much checking the Spanish needs, and a transcript that reads fluently can still leave you doing a full audio review.
More cleanup in Spanish doesn’t automatically mean language switching is the problem, or that another transcriber would do better. The comparison I’d want is the same Spanish audio through Muse and another transcription tool your team already has access to. Keep the recording fixed and change the tool.
That answers a different question from @quantumlab’s separate-excerpt test. Splitting the recording could help you find a better way to feed material into Muse. Comparing tools would help you decide whether Muse deserves to stay in your workflow at all. I wouldn’t spend much time rearranging recordings before checking whether the alternative handles the original file better.
For that comparison, use a passage you’ve already corrected against the audio as your reference. Don’t judge the outputs by which looks more polished. Put the missing connectors side by side, along with any changed instructions or terminology. I’d separate punctuation and paragraph breaks from wording errors, too. For your training material, I’d rather fix a messy paragraph than restore a missing condition.
The useful result isn’t simply “this transcript has fewer mistakes.” Look at whether the other tool preserves the specific words Muse drops. If it does, even while making different formatting mistakes, that gives you a concrete reason to consider switching. If both stumble in the same places, I’d examine those moments in the recording before blaming Muse’s Spanish support broadly. That wouldn’t prove the audio is at fault, but it would change what I’d investigate next.
I agree with @nextbear2628net that review time matters, but it needs a baseline. “Spanish takes longer” leaves you stuck with an unpleasant workload. “Muse requires these repairs, while the alternative requires those” gives your team an actual choice. Based on your recordings, Muse’s Spanish output isn’t meeting the same bar as its English output. Whether that’s a reason to replace it is the comparison still missing.
If I understand correctly, your expected answer would mention the specifics of your team’s recordings rather than general observations about Muse’s supposed proclivity towards Spanish or otherwise. Based on your description, I would not give the tool a pass for your team’s Spanish recordings, but I would ask if this conclusion was drawn from a uniform body of text or if there were specific speakers who tended to require more extensive editing.
This is the concern I have with the suggested comparison between tools: the chosen excerpt may have failed to include the exact portion that required intensive editing. Before resuming the experiment, you may want to review the edits that Muse created for the excerpts that you have already edited. Does it appear that you are making the same number of minor edits throughout the recording, or do you find yourself making more substantial edits whenever a particular speaker begins talking? It is possible that you already have enough data to make a recommendation, if you can review the recordings and identify the points at which Muse required extensive editing. I would not make a recommendation based on accent, audio quality, or language switching. Establish a point of comparison, such as whether the majority of the problematic text appears in the prepared presentation or the following discussion.
If you resume the experiment, make sure to include the less problematic recordings in your final recommendation. It would be easy to recommend Muse for one problematic recording if the tool has been demonstrated as ineffective for other similarly-structured recordings with different speakers. Your team may need an alternative transcription tool that can handle the specific recordings that you will be using, rather than one that can handle any recording. If Muse were to improve the text of the principal speaker while failing to alter the text transcribed from another speaker’s text, it would not be a valuable tool for your team.
If these concerns are resolved to your satisfaction and if you resume the experiment, you might want to consider reserving Muse for the recordings that require the fewest total edits and deferring the others to different tools. Revealing this preference would not be an absolute rejection of Muse as a tool, but it might allow you to resume the experiment more efficiently. It would not be reasonable to recommend the Muse software for use with most of your team’s recordings while reserving another tool for the recordings that required the least amount of editing. For your team’s purposes, it is not the quantity of text that has been transcribed that is important, but the survival of particular speakers’ text fragments.
Pull up a handful of the spots where the connectors vanished and look at what’s happening in the audio right before them. My bet is they cluster around fast, unstressed delivery. Short function words like ‘si,’ ‘de,’ ‘lo,’ ‘que’ carry almost no acoustic weight, especially when a speaker runs them into the next word, and that’s exactly the kind of thing speech models drop first. If that’s the pattern, it’s not really ‘Muse is bad at Spanish’ in the abstract, it’s Muse struggling with weak syllables in connected speech. Which, honestly, most transcribers do.
That changes what a tool swap would actually tell you. @zeromaker9171’s comparison is worth doing, but if both tools choke on the same rushed ‘si’ then you’ve learned the problem lives in the audio pacing, not the software. I’d run that test, but I’d go in expecting the alternative to miss some of the same words, not all of them.
The thing nobody’s mentioned yet is that you can sometimes get those words back without switching anything. If your recordings allow it, re-feeding a slowed-down version of the trouble sections can recover function words the model skipped at normal speed. It’s slower and it’s annoying, but for training material where a missing ‘si’ flips the meaning, it beats retyping from scratch. Worth trying on one clip before you commit to a full retranscription.
Where I’d push back a little on @neonarchitect3877zon is the speaker-by-speaker framing. That matters, sure, but I suspect the bigger split is prepared speech versus live back-and-forth. The presenter reading slides will transcribe clean. The moment people start talking over each other in the discussion, connectors evaporate regardless of who’s speaking. If that’s what you see, splitting work by section type gets you further than sorting by speaker.
If your team uses these transcripts to make quizzes or written procedures, I would avoid including the (unchecked) Spanish text to the process for the time being. For your recordings I would not rely on Muse’s Spanish output to be used as additional material for training, even in cases where it sounds nice and fluent. Tracking the cleaning time makes sense to me, but I would add checks for anything produced from the original transcript rather than relying on the fact that a transcript correction will fix everything.
Fixing an occasional typo is cleanup, while repeatedly restoring missing Spanish words starts to look like unpaid product testing. Before trying every possible way to rearrange your recordings, I’d send Muse’s support a short clip you’re allowed to share, its unedited transcript, and the corrected wording. Ask specifically whether there’s a setting relevant to these omissions or whether this is a limitation they recognize. The comparisons suggested here could help, but you shouldn’t have to run a small research department just to find out what the vendor expects its Spanish transcription to handle.
