Am I restarting my router the right way?
My internet has been dropping a lot, so I tried restarting my router, but I’m not sure I’m doing it correctly. I usually unplug it and plug it back in right away, but the connection still acts up. Can someone explain the proper way to restart a router and whether waiting longer actually helps fix Wi-Fi issues?
Honestly, I used to be the “unplug and immediately plug back in” type. Internet down, frustration up, plug yanked. But after fixing nothing a few times in a row, I actually looked into why the wait matters.
The short version: your router has capacitors inside, basically tiny capacitors that act like miniature batteries. Even after you pull the power, they can hold just enough charge to keep memory chips running for a few seconds. So if you plug back in too fast, the RAM never fully cleared, and you haven’t actually done a clean restart. Waiting around 10 seconds ensures the capacitors drain and the RAM clears properly.
Now, most ISP guides and tech articles recommend going even longer. The common advice is to wait at least 30 seconds with the router unplugged before powering it back on. Is 30 seconds always necessary? Probably not for every situation. Not all problems require a full discharge, which is why some issues can be solved without the wait. But if you’re troubleshooting something persistent, the extra seconds are worth it.
There’s also a distinction worth knowing. Rebooting through the router’s software interface restarts the hardware and firmware, while physically unplugging it clears the cache for a truly clean start, which can be more effective against performance issues or minor security threats. So the physical power cycle is actually the more thorough option.
My routine now: unplug, count to 30 (or just walk to the kitchen and come back), plug in, and wait for the lights to stabilize. Takes maybe 2 minutes total and works noticeably better than the impatient yank-and-replug.
For more takes on this, there’s a good ongoing Reddit discussion over where people get into the specifics.
Unplugging and plugging it right back in is the weak version of a restart. So, no, you are not doing it the best way.
I agree with @mikeappsreviewer on one part, the instant replug is often useless. Where I differ is this, if your internet keeps dropping after a proper power cycle, the router is often not the main problem.
Do this instead.
  1. Restart the modem too, if you have a separate modem and router.
  2. Power both off.
  3. Wait about 20 to 30 seconds.
  4. Turn on the modem first.
  5. Wait until its online light is stable.
  6. Turn on the router after that.
  7. Wait 2 to 5 minutes before testing.
Order matters. If the router starts before the modem fully reconnects, you get flaky service or no IP lease. People miss this all the time.
Also check the boring stuff. Loose coax cable. Damaged ethernet cable. Hot router. Old firmware. Router shoved in a cabnet. Those cause random drops more than people think.
If it still drops, test on one wired device. If wired also fails, call your ISP. If wired is stable but Wi-Fi dies, your router or Wi-Fi setup is the issue. That narrows it down fast.
Unplugging it and jamming it back in instantly is basically just you doing cardio for the power cord.
I mostly agree with @mikeappsreviewer and @shizuka, but I’d add this: if your router needs frequent restarts, don’t treat that like normal maintenence. A healthy router should not need babysitting every few days. That’s the part people skip.
What I’d check after a proper restart is the pattern. Does it drop at the same time every day? Only on Wi-Fi? Only when streaming or gaming? If the answer is yes, that points to congestion, overheating, interference, or failing hardware more than a bad reboot method.
Another thing, look at the router logs if your model has them. People never do this, but it can show repeated disconnects, DHCP issues, WAN failures, or kernel crashes. That tells you way more than rebooting it 6 times and hoping for magic.
I’ll slightly disagree with the “pulling power is always better” idea too. On some routers, hard power cuts over and over are not ideal if the firmware is already unstable. An admin-page reboot can be cleaner for routine restarts, while a full unplug is better when it’s frozen or acting really weird.
If the drops keep happening and the router is a few years old, honestly, it may just be dying. Routers get flaky before they fully quit. Seen it a bunch. Not every internet problem is some deep mystery lol.
One small disagreement with @shizuka, @voyageurdubois, and @mikeappsreviewer: people focus way too hard on the restart ritual itself. Yes, the timing matters, but if your internet is dropping a lot, the more useful question is what changes right before the drop.
Quick way to tell:
  • If the Wi-Fi icon stays connected but sites stop loading, that is usually modem, ISP, or DNS.
  • If only phones and laptops drop, but wired devices stay fine, that is usually Wi-Fi interference or router radio issues.
  • If everything dies and comes back after a few minutes, suspect overheating, bad power adapter, or line trouble from the ISP.
A sneaky one is the power brick. Failing adapters cause random reboots that look exactly like “bad internet.” People replace the router and keep the dying adapter.
Also, do not keep the router on auto-channel forever if you live in an apartment. Auto can make dumb choices. Scan nearby networks and set a cleaner 2.4 GHz or 5 GHz channel manually.
Pros for the ': can improve readability if you are comparing gear or troubleshooting notes in one place. Cons for the ': not relevant unless you are actually shopping or documenting setup details.
If drops happen daily, log the exact time for 2 or 3 days. That pattern tells more than another reboot.
