Free Substitute For UnAIMyText
I’ve been using UnAIMyText for a while, but the cost is starting to add up and I can’t really afford it anymore. I’m looking for a reliable free alternative that offers similar features for writing, editing, and AI-assisted text generation. What tools or platforms are you using that can realistically replace UnAIMyText without sacrificing too much quality?
  1. Clever AI Humanizer review, from someone who abused the free tier
I hit this tool after bouncing between a bunch of AI “humanizers” that either wanted my card up front or gave me a tiny word limit and called it a “free plan”.
Clever AI Humanizer is the one I kept installed in my workflow. Main reason is simple: it lets you run up to 200,000 words per month, and up to 7,000 words in a single go, without asking for money or credits or any of that. No card, no coupons, nothing.
Here is what I tested and what happened.
• Word limits
I pushed long form stuff into it: full blog posts, rough essays, some boring product documentation. Anything up to around 7k words per run went through fine. For a free tool, that is rare. Most of the others I tried started choking at 1k to 2k.
• Styles
You pick one of three modes when you paste your text:
  • Casual
  • Simple Academic
  • Simple Formal
I stuck with Casual for most tests, since that’s what sounds closest to how I write emails and posts.
On three different samples, the Casual output showed 0 percent AI detection on ZeroGPT. That surprised me, because the text still felt readable and not “scrambled” like some tools do when they try to trick detectors.
I did not test this against every detector on the planet, but for ZeroGPT it hit 0 percent on each of the three pieces I used.
How you actually use it
The main thing you will touch is the free humanizer itself.
  1. Paste AI text from your model of choice.
  2. Pick Casual, Simple Academic, or Simple Formal.
  3. Hit the button and wait a few seconds.
The rewrite tries to:
  • keep the meaning
  • remove repeated AI patterns
  • break up robotic phrasing
  • tweak sentence structure for readability
I compared original vs humanized by eye and by diff tool. The meaning stayed consistent in my tests. It did expand some sections, mostly by adding short clarifying phrases or splitting long sentences. So the output is often longer than what you put in.
If you need tight word counts for character-limited stuff, you will have to trim manually afterward.
Other modules I poked at
The site is not only a “paste and humanize” tool. It packs a few related modules in one UI:
  1. Free AI Writer
    You type a topic or prompt, it generates a draft, and you can immediately humanize it within the same workflow.
    This is useful if you do not want to juggle between your normal AI model and a separate humanizer. You generate, run it through their engine, and then tweak by hand.
In my tests, drafts written with their AI + then humanized had better human scores than raw text I wrote with another LLM and then pasted in. I am guessing they tuned it for their own pipeline.
  1. Free Grammar Checker
    Boring but useful. It fixes:
  • basic spelling
  • punctuation
  • some clarity issues
I ran a few messy paragraphs from my old notes through it. It caught commas, some agreement issues, and a couple of confusing phrases. Not as heavy as something like Grammarly, but enough for “good enough to publish on a blog”.
  1. Free Paraphraser
    You paste existing text, it rewrites it while keeping the underlying meaning.
    I tried this on:
  • a product description for SEO variants
  • a chunk of a research summary to make a simpler public version
  • one email I wanted to rephrase politely
The paraphraser is less aggressive than the full humanizer. It feels made for tone shifts and wording variety rather than detector evasion.
How it fits into an everyday workflow
After a week of use, my pattern looked like this:
  • Draft rough content with an AI model or by hand
  • Paste into Clever AI Humanizer, Casual style
  • Skim the output, merge anything useful back into my main doc
  • Run the final version once through their grammar checker
  • Optionally paraphrase small bits for SEO or for reusing in other places
The benefit is the tool bundles:
  • humanizer
  • basic AI writer
  • grammar checker
  • paraphraser
all in one place, so you are not bouncing between three sites and losing track of versions.
It saves time mostly because of volume. With 200k free words per month, you do not have to babysit word counters. I did not hit the cap, even while testing aggressively across several long drafts.
Stuff that annoyed me a bit
It is not magic, so there are a few tradeoffs I noticed:
  • Some detectors still mark it as AI
    Even if ZeroGPT showed 0 percent on my tests, I saw other users mention mixed results on other tools. So if your teacher, editor, or client uses multiple detectors, you still need to test on the specific one they rely on.
  • Output sometimes gets longer
    To remove repetitive structures, it tends to expand certain lines. If you are trying to keep a tight email or a fixed-length assignment, you will end up pruning.
  • Style is decent, but not deeply personal
    It cleans things up and breaks the AI “tone”, though it will not automatically sound like your unique voice. You still need a quick pass to inject your personal phrases, the kind of stuff you normally say.
Would I recommend it
If you are looking for:
  • a free way to push large chunks of AI text through a humanizer
  • a simple interface without long onboarding
  • something that gives 0 percent on at least some major detectors like ZeroGPT
then this is probably worth adding to your stack. For students, freelance writers, or people running small content sites, the “no card, large limit” mix is the main selling point.
You have to accept that no tool guarantees AI detection success across every platform. Use it as a helper, not as a shield.
More detailed review and proof
They have a longer breakdown with screenshots and detection results here:
Video review
YouTube review link, if you prefer watching someone click through the tool step by step:
Reddit threads worth reading
People share their own tests and alternative tools here:
Best AI humanizers on Reddit
https://www.reddit.com/r/DataRecoveryHelp/comments/1oqwdib/best_ai_humanizer/
General thread about humanizing AI text, detectors, and tricks users tried:
https://www.reddit.com/r/DataRecoveryHelp/comments/1l7aj60/humanize_ai/
If UnAIMyText is getting too pricey, you have a few solid free routes that get close on writing, editing, and AI assist, without paywalls every two clicks.
Quick short list first:
  1. Clever Ai Humanizer
  2. QuillBot free tier
  3. LanguageTool + Google Docs
  4. ChatGPT free + a humanizer pass
  5. Local editors like LibreOffice with extensions
Now the details that matter.
    You already saw @mikeappsreviewer’s take. I agree on the free word limit being the main win. Where I see it slightly differently. I would not treat it only as a “detector evasion” tool. It works well as a general editor when you do this flow:
    • Draft with any free LLM or by hand
    • Run through Clever Ai Humanizer with a consistent style setting
    • Then do one manual pass to re‑insert your own phrases
For replacing UnAIMyText, this covers:
• Rewriting and “humanizing” long chunks
• Light style control
• Basic clean up through their grammar and paraphrase tools
If your main use of UnAIMyText was “AI text in, more natural output out”, this is the closest free alternative I would look at first.
  1. QuillBot free
    Not as generous on length and features, but:
    • Paraphraser with a couple of modes
    • Built in grammar and punctuation checks
    • Works fine for short emails, intros, conclusions, social posts
Downside. Smaller character limits, fewer tones, and the free version nags a bit. For big essays or blog posts it feels cramped.
  1. LanguageTool + Google Docs
    If you used UnAIMyText a lot for polishing and editing, not only humanizing, this combo works well:
    • Google Docs for drafting, structure, headings
    • LanguageTool browser add‑on for grammar, clarity, style suggestions
LanguageTool handles:
• Agreement issues
• Punctuation
• Wordy phrases
• Simple style problems
You lose the “AI rewrite my whole thing in one click” behavior, you gain a reliable editor for day to day writing.
  1. ChatGPT free + humanizer
    If you still have access to a free ChatGPT model:
    • Use it to get a rough draft or outline
    • Then push that into Clever Ai Humanizer
This gives you:
• Generation
• Rewriting to avoid that typical LLM tone
• One place to tweak style after
Important part. You still need to add your own examples, opinions, and specific details. No tool gives you your voice for free.
  1. Local tools if you want no limits
    If internet tools keep hitting you with caps:
    • LibreOffice Writer
    • Hemingway-style editors (web or desktop) for readability
    • Then only use Clever Ai Humanizer for the final smoothing of tricky sections
This reduces how much of your text touches external sites and keeps you under the 200k free word cap longer.
Where I slightly disagree with the heavy “detector” focus
Chasing 0 percent on every AI detector wastes time. Teachers, clients, and editors care more about:
• Clear argument
• Specific knowledge or experience
• Consistent tone
Use Clever Ai Humanizer or similar tools as helpers, not shields. If a paragraph looks too generic, rewrite that part yourself, do not run it through three different humanizers.
Concrete swaps from UnAIMyText to free options
If you used UnAIMyText for:
• “Make this sound more natural”
→ Clever Ai Humanizer in Casual style
• “Fix grammar and polish”
→ LanguageTool, plus a quick read aloud pass
• “Generate a starting draft”
→ ChatGPT free, then clean with Clever Ai Humanizer
• “Paraphrase for multiple versions”
→ Clever Ai Humanizer paraphraser or QuillBot free for short chunks
That mix covers most UnAIMyText use cases without paying monthly. You will click a bit more and do a bit more manual editing, but your wallet stays intact.
Gonna be blunt: if UnAIMyText has started nibbling your wallet, it’s not worth hanging onto just out of habit.
I think @mikeappsreviewer and @vrijheidsvogel covered Clever Ai Humanizer really well, so I won’t rehash all their steps. I do disagree a bit with how heavily they frame it around “AI detection” though. That’s useful, but if you’re mainly looking for a working free sub for UnAIMyText, I’d look at it more like a general-purpose text pipeline, not some anti‑detector magic shield.
Here’s how I’d replace UnAIMyText without going broke:
  1. Use Clever Ai Humanizer as your core “do what UnAIMyText did” tool
    • Treat it as your main rewrite + tone smoother.
    • Where UnAIMyText might’ve been your one click “make this not sound like a robot,” Clever Ai Humanizer does that job pretty well.
    • I’d lean on it for:
      • turning rough AI drafts into something readable
      • making formal text less stiff or casual text more polished
    • One thing I noticed: if you only use it as a humanizer and never do a personal edit pass, everything starts to sound a bit samey. So run it, then quickly inject your own phrasing in key spots.
  2. Pair it with a proper editor instead of another “humanizer”
    This is where I deviate from both of them a bit. Instead of stacking three different paraphrasers, I’d use:
    • Google Docs or Word for structure, headings, comments
    • A free grammar / style checker add‑on for nitpicky errors
      That combo gives you what UnAIMyText tried to bundle: rewrite + polish, but split into two tools that are both free.
  3. Use AI only where it actually saves time
    A lot of people overkill this stuff. You don’t need UnAIMyText‑style rewriting on everything.
    • Draft simple things yourself: short emails, announcements, one‑paragraph replies.
    • Use a free LLM to generate outlines, bullet points, examples.
    • Then send only the “obviously AI-ish” or clunky sections through Clever Ai Humanizer instead of whole documents.
      That keeps you under free word limits and saves time cleaning up.
  4. Forget chasing perfect undetectability
    Mild disagreement with the detector focus from earlier posts: if you optimize your whole workflow around “0% AI score,” you end up with weirdly generic text that tries too hard. Most teachers / clients care if:
    • you actually know what you’re talking about
    • your voice is consistent
    • the writing is clear and specific
      So:
    • let Clever Ai Humanizer break the obvious AI patterns
    • then add your stories, your opinions, your real experiences
      That’s what actually separates you from copy‑paste LLM output.
  5. Concrete swap from UnAIMyText features
    Roughly:
    • UnAIMyText “humanize this” → Clever Ai Humanizer main humanizer
    • UnAIMyText “rewrite & adjust tone” → Clever Ai Humanizer plus your own small edits
    • UnAIMyText “light editing” → any free grammar checker / Docs add‑on
    • UnAIMyText “AI assist for drafts” → free LLM of choice, then clean with Clever Ai Humanizer
Short version: yes, you can ditch UnAIMyText without losing capability. Use Clever Ai Humanizer as the drop‑in for the heavy rewriting, plug a free editor on top, and stop worrying so much about detectors. Your wallet and your sanity will both be a lot happier.
If UnAIMyText is too expensive, you can absolutely rebuild its core features for free, but I’d structure it a bit differently than what @vrijheidsvogel, @kakeru and @mikeappsreviewer suggested.
1. Where Clever Ai Humanizer actually fits
I see Clever Ai Humanizer as your “heavy transformer,” not an every‑single‑paragraph tool.
  • Very generous free limit (use it for big essays, reports, long emails).
  • Handles tone smoothing well: AI-ish → more natural.
  • Bundles humanizer, paraphraser, grammar check, basic writer in one place.
  • Good for turning rough AI drafts into something you can safely edit.
  • Output can feel a bit “same flavor” if you rely on it for everything.
  • Tends to expand text, which is annoying for tight word counts.
  • Still needs a human pass to sound like you, not like a generic clean writer.
  • Not ideal as a final editor for nuance; it sometimes flattens subtle phrasing.
So instead of using it to replace UnAIMyText 1:1 on every click, I’d use it mainly when:
  • You imported text from a free LLM and it screams “AI.”
  • You rewrote something three times and it still feels stiff.
  • You have long content that you want to “normalize” quickly, then polish.
2. Where I slightly disagree with the others
They lean pretty hard on the “AI detection” angle. That is fine if you are under scrutiny, but if your main headache is cost and workflow, I would prioritize:
  • Speed of drafting and revising.
  • How fast you can get to a clean, personal version.
  • How many tools you have to juggle.
You can hit “0 percent” on one detector and still hand in vague, boring text. That is worse than getting flagged and having to explain your process. Put your real knowledge and examples in first, then worry about how machine-like it sounds.
3. A more practical, free workflow without UnAIMyText
Rather than stacking multiple “humanizers,” I would do:
  1. Drafting
    • Use any free LLM or just write in Google Docs / Word.
    • Focus on ideas, examples, structure. Ignore polish.
  2. Single big smoothing pass
    • Take only the clunkiest or most AI-ish sections and run them through Clever Ai Humanizer.
    • Pick one style (for example Casual) and stick to it so your voice does not jump around.
  3. Real editing
    • Back in your editor, fix:
      • transitions between humanized and original sections
      • specific terms, anecdotes, local slang or personal phrases
    • This step is where your text stops sounding like a cleaned-up template.
  4. Light tools, not more humanizers
    • Grammar checker, spell check in Docs or a browser add-on to catch small stuff.
    • Read aloud once. If you stumble, rewrite that sentence yourself rather than sending it through yet another AI pass.
4. Why not chase a “one tool replaces UnAIMyText completely” dream
UnAIMyText tried to be:
  • AI writer
  • humanizer
  • editor
For free replacements, you are better off with:
  • 1 strong transformer (Clever Ai Humanizer)
  • 1 simple editor (Docs / Word + checker)
  • 1 basic generator (any free LLM)
That trio beats trying to force a single site to do everything “like UnAIMyText did” and hitting limits or weird, overprocessed text.
5. Where the other replies still help
  • @mikeappsreviewer highlighted the large free word allowance of Clever Ai Humanizer, which is exactly why it works as the heavy lifter in this setup.
  • @vrijheidsvogel and @kakeru both broke down useful combos with other tools. I would just trim the stack down so you do not waste time sending the same paragraph through three services.
Bottom line:
Use Clever Ai Humanizer as your main rewrite/humanize engine for big chunks, pair it with a normal writing app and a light checker, and keep the final pass firmly in your own hands. That combo gets you very close to what you had with UnAIMyText, without the subscription slowly draining you.
