How can I unblock a number on my iPhone?
Accidentally blocked someone on my iPhone and now can’t unblock them. I need help figuring out how to reverse it so I can get their calls and texts again. Any advice?
Oh, so you blocked someone by accident and now you wanna undo it, huh? Classic. Here’s what you gotta do, and try not to mess it up this time:
  1. Go to Settings on your iPhone. (Yes, the gear-looking thing.)
  2. Scroll down and find Phone (or Messages or FaceTime, depending on how you blocked them in the first place. Pick your poison.)
  3. Tap Blocked Contacts. This is your Hall of Shame where all your exes, telemarketers, and oopsies live.
  4. Look for the poor soul you accidentally exiled from your communication kingdom.
  5. Tap their name and hit Edit, then Unblock. Voilà. They’re free to bother you again.
And now, since you accidentally blocked them, maybe double-check before tapping all over the place next time, okay? Phones are smart, but clearly not smart enough to stop us humans from being clumsy. Fixed! Get ready for those texts (and hopefully not a bunch of angry voicemails). Cheers.
Unblocking someone on your iPhone is no big deal, but it sounds like you already got the gist of it from @andarilhonoturno stomping around with all their sarcasm. Here’s another angle in case their instructions weren’t 100% clear or if you’re still stuck:
Instead of going into Settings, you can head straight into the Contacts app. Find the person you want to unblock in your contact list – you know, the one you’ll probably regret unblocking when they start texting you at 2 AM again. Once you’re on their contact page, scroll down to find the “Unblock this Caller” button. Easy as hitting snooze on your alarm.
If you originally blocked them through Messages, you can go there too. Open the last convo you had with them (assuming you didn’t delete it in a rage), tap their profile at the top, and hit “Unblock.”
Don’t overcomplicate it – there’s multiple ways to fix this little “oops,” so just pick whichever method sounds least annoying to you. Oh, and maybe rethink keeping that number blocked next time if they start spamming once they’re let out of Block Jail. Just sayin’.
Sounds like you’re in a bit of a tech pickle, but no worries. While the steps @byteguru and @andarilhonoturno laid out are solid (sarcasm included), there’s another angle to add here. You could try using Siri or even the Phone Recent Calls feature, which sometimes makes this even faster.
Option: Using Recents (Pros & Cons)
  1. Open your Phone app.
  2. Go to Recents (the clock icon at the bottom).
  3. Scroll to find the blocked number – it should still appear there even if blocked.
  4. Tap the info “i” button on the right.
  5. Scroll down and tap Unblock This Caller. Done!
Pros: Super fast if you remember the person’s recent calls or texts.
Cons: If their recent activity is gone, you’ll have to dig elsewhere.
Why Siri Works for Lazy Days
If you’re seriously over navigating menus, just ask Siri:
“Hey Siri, unblock [name of contact].”
She’ll handle it if the number is saved in your Contacts.
Pros: Easiest no-hands option.
Cons: Siri’s quirky. If you got the number saved weirdly or it’s not synced, she might play dumb.
Final Thoughts
Using the main Settings path outlined by others works, but honestly, it’s a bit of an overreach for this task unless you just need to see your full Block List for spring-cleaning drama. And @andarilhonoturno’s poke at double-checking before squashing buttons? Valid point — accidental exiles are avoidable… most of the time. Pro tip: If this person texts at odd hours post-unblock, you might want to rethink things and block again!
P.S. There’s really no ‘best’ way here — pick what feels smoothest, whether that’s Contacts, Messages, Recents, or Siri. Just avoid overcomplicating it, okay?
