How do I sign out of Netflix on my smart TV?
I’m stuck signed into my Netflix account on a smart TV at a rental place and can’t figure out how to log out. The menus look different from the instructions I found online, and I’m worried the next guest might use my profile. Can someone walk me through the exact steps to sign out of Netflix on a TV, or at least deauthorize this device from my account settings?
This trips a lot of people up, especially with weird rental TVs. Here’s what usually works, in order of easiest to hardest.
  1. Try the Netflix in‑app menu
    On most smart TVs:
    • Open Netflix
    • On the left side, move to the menu until you see: Get Help or Settings
    • Open that, then scroll to Sign out
    • Confirm
If you do not see Get Help:
• Open Netflix
• Move all the way left until you see your profile icon at the top
• Go down to Settings or Help and look for Sign out or Log out
  1. Use the remote button combo
    This works on many models when the menus look different.
Open Netflix first. Then on the TV remote, press in this exact order:
Up, Up, Down, Down, Left, Right, Left, Right, Up, Up, Up, Up
A diagnostics screen should pop up.
Choose Sign out or Deactivate.
Sometimes you need to do it kinda fast. If it does nothing, try again a bit quicker.
  1. If you still do not see a sign out option
    Some rental or hotel TVs use a built‑in “hotel mode” or a set‑top box.
Try these:
• Look for a “Home” or “Info” button on the hotel remote.
• See if there is a hotel menu with “Reset” or “Guest sign out”.
• If Netflix is inside another app like “Hotel TV” or some hub, open that app’s settings and log out there.
  1. Use “Sign out of all devices” from your account
    This is the nuclear option, but it works even if you left already.
On your phone or laptop:
• Go to netflix dot com in a browser
• Log in
• Click your profile icon, then Account
• Under Security and Privacy, pick “Sign out of all devices”
• Confirm
It can take up to 15 minutes for every device to drop you. In my case it took about 5 minutes on a Samsung TV and about 10 on an LG.
After that, anyone who opens Netflix on that rental TV will see the login screen again.
  1. Change your password too
    If you used a shared Wi‑Fi or you are worried someone saw your password:
    • Change your Netflix password from the Account page
    • Check “Require all devices to sign in again with new password” if you see it
That forces every TV, phone, and tablet to log in again.
If none of this works, it is often because the property locks the inputs and apps. In that case, the “sign out of all devices” plus password change is your best bet.
Couple of extra tricks on top of what @reveurdenuit already said, especially if the TV is being weird because it’s a rental / hotel setup.
  1. Check if it’s actually a hotel Netflix, not your own
    Some newer hotel/rental TVs have a special “Netflix for guests” integration. If you saw a splash screen that said something like “Sign in with your Netflix to enjoy your stay” or had a note about “your account will be removed at checkout,” then:
  • Back out of Netflix to the main TV menu
  • Look for something like:
    • “Guest Services”
    • “TV Portal”
    • “Hotel / Property Menu”
    • “Cast / Stream from your device”
  • Inside that, there’s often a “Clear my data” or “End session” or “Sign out of streaming apps” button that wipes Netflix, YouTube, etc. at once.
If that exists, use that instead of relying only on the in‑app sign out. It clears cached tokens that sometimes survive normal logouts.
  1. Hard reset the TV’s smart system (if you’re still there)
    This is more aggressive than what was suggested before, and yeah, it can annoy the property if you go nuclear, so use some judgement.
Look in the TV’s main Settings (not Netflix):
  • Open TV Settings
  • Go to General or System
    • “Reset Smart Hub”
    • “Reset TV to initial settings”
    • “Erase all personal data”
      If it says it will remove accounts / apps / logins, that’s what you want.
      On many Samsungs, “Reset Smart Hub” specifically logs out of all streaming apps without changing picture settings, which is a nice middle ground.
  1. If you already left and can’t touch the TV again
    Here’s where I half‑disagree with relying only on “Sign out of all devices” like @reveurdenuit mentioned: it’s helpful, but sometimes Netflix sessions on certain hotel systems hang on for a bit longer or the box caches your profile name. To be safer:
  • First: Change your Netflix password
  • Make sure to check any box that says “require all devices to sign in again”
  • Then: Use “Sign out of all devices” in your account settings anyway
    Doing both is overkill, but it guarantees that even if the TV somehow keeps a stale token, it can’t actually stream.
  1. Check your “Recent device streaming activity”
    On netflix dot com:
  • Go to Account
  • Look for something like “Recent device streaming activity”
  • You’ll see the device type and approximate location
    If you still see that TV or that city streaming after you did the sign out + password change, something didn’t propagate yet. Wait 15–30 minutes, refresh, and check again. If it still shows up, open Netflix Help chat and explicitly tell them “This is a rental TV I can’t access, please kill any active sessions from that device.” They can force‑kill sessions from their side.
  1. For future rentals so you don’t have to deal with this again
    Honestly, logging into TVs you don’t control is kind of a trap. Safer alternatives:
  • Bring a cheap streaming stick (Roku, Fire TV, Chromecast) and plug into HDMI; log into that instead of the house TV
  • Or use casting only: open Netflix on your phone and cast to the TV if it supports it, without typing your password into the TV at all
  • Or use a “throwaway” Netflix profile & immediately nuke your sessions when you leave
I’ve had one Airbnb where the “sign out” button in Netflix literally did nothing because of the way the TV was locked down. In that case, password change + sign out of all devices was the only thing that actually cut it off, even though the TV still showed my profile name until the owner rebooted it. That’s why I don’t fully trust the in‑app sign‑out alone on these setups.
