How To Clean Junk Files On An IPhone That Keep Filling My Storage Overnight?
My iPhone storage keeps filling up overnight even after I delete photos, apps, and downloads. The System Data or junk files seem to return, and I need help safely clearing them and preventing the issue from happening again.
The first place to check is Settings > General > iPhone Storage. Give it a moment to load the full breakdown. That will tell you what is actually taking up space, which is more useful than assuming the iOS update filled the phone with system junk.
I had this happen on an older 64 GB iPhone after an update. Storage warnings started appearing, and apps kept reloading whenever I switched between them. The update did need some temporary room, but most of my storage was actually tied up in years of photos, videos, screenshots, downloads, and accumulated app data.
If Photos is near the top of the storage list, I would deal with that first. It usually gives you the most space back for the time spent. My library has several thousand images, so sorting everything manually isn't practical. I use Clever Cleaner to group duplicate and similar photos, find large videos and old screenshots, and review Live Photos separately.
Smart Cleanup is useful for clearing the obvious clutter first. After that, I usually spend a few minutes in Swipe mode going through older pictures individually. For groups of similar shots, the app recommends which photo to keep. That helped a lot with batches from vacations and family events. The analysis happens locally on the iPhone, there are no ads, and the free version covers routine cleanups pretty well.
Once the photo library is under control, these are the other places worth checking:
  • Remove apps you haven't used in months. If you might want one again, choose Offload App so its documents and data are kept.
  • Open the Files app and look through Downloads. Old PDFs, ZIP files, and forgotten documents can take up more room than expected.
  • Check Netflix, Spotify, YouTube, Apple Music, and similar apps for offline downloads you no longer need.
  • If Messages is using a lot of storage, delete large video attachments from old conversations instead of wiping entire chats.
Also check the Recently Deleted album after removing photos and videos. iOS keeps deleted items there for 30 days, so your available storage may barely change until you empty it. That was why deleting hundreds of photos initially seemed to make no difference on my phone. Once I cleared that album, the space showed up almost right away.
I wouldn't focus too much on System Data. Its size changes as iOS handles caches and temporary files, especially around an update. App Store cleaning apps cannot directly remove iOS system files because Apple doesn't give them that access. If System Data jumps after an update, it may shrink again over the next day or two.
On a 64 GB iPhone, keeping around 5–10 GB available makes a noticeable difference. Since leaving that buffer, I've had fewer storage warnings, updates install without complaining, and the phone doesn't slow down or reload apps as often.
Deleting more photos can make this harder to diagnose, because a background process may simply consume the newly freed space again. If storage returns overnight, take a screenshot of the iPhone Storage screen before bed and compare it in the morning. Check whether System Data grew or whether an app such as Podcasts, Music, Messages, Photos, or a streaming app did.
@the_cursor is right that cleaner apps cannot directly purge iOS system files, but I would not just wait if this repeats nightly. Turn off automatic media downloads, remove completed podcast episodes, clear Safari history and website data, and restart the phone. You can leave it in Airplane Mode for one night as a quick test. If the storage stops growing, syncing or automatic downloads are the likely cause.
If System Data keeps expanding even with no network connection, install any pending iOS update and restart again. The last-resort fix is an encrypted backup followed by erasing and restoring the iPhone. That is more work, but it is safer than repeatedly deleting personal files while a broken cache or indexing process keeps taking the space back.
If it only fills overnight while the phone is charging on Wi-Fi, check Photos settings for “Download and Keep Originals.” iCloud may be pulling full-size files back onto the phone after you free space. Switch to “Optimize iPhone Storage” and give it time to rebalance. A cleaner app like Clever Cleaner can reduce photo clutter, but it cannot stop an iCloud download loop. Don’t disable iCloud Photos or delete more pictures until you confirm they are safely synced.
Open the largest few apps in iPhone Storage and compare “App Size” with “Documents & Data” before deleting anything else. A 300 MB app holding 12 GB of data is a much better suspect than the System Data label.
Offloading is not very useful in that situation because it keeps the app’s documents and data. First look inside the app for a cache or download manager. Social media, mapping, podcast, cloud-storage, and messaging apps can quietly rebuild thumbnails, offline files, or synced attachments while the phone is charging. If there is no clear-cache option, confirm that anything important is synced, then use Delete App and reinstall it. Watch out for unsent drafts, downloaded media, authenticator data, and chats that are stored only on the phone.
For the overnight test, disable Background App Refresh for the suspect app and turn off its automatic downloads. Leave everything else unchanged for one night. If storage stays stable, you have narrowed it down without wiping the whole phone. If the same app immediately grows again after reinstalling, the content is probably being restored from its account rather than created by iOS.
Clever Cleaner can help when Photos is genuinely the large category, but it will not fix a runaway app cache. I would treat a backup, erase, and restore as the final step only after checking Documents & Data, since a restore can take hours and may bring the same synced content straight back.
Airplane mode overnight is the fastest test in this whole thread, so start there before touching anything else. If storage stays flat with no network, it’s a sync or download loop, not iOS junk, and no cleaner app changes that. Clever Cleaner only helps once you’ve confirmed Photos is the actual culprit.
