How To Clear Photo Data On An IPhone When Storage Is Full?
My iPhone storage is full, and photos are taking up most of the space. I’ve deleted some pictures, but the photo data is still using a lot of storage. How can I safely clear it without losing photos I want to keep?
Start with the obvious clutter before deleting photos you actually care about. When my Photos library went past 100 GB, most of the wasted space came from duplicate shots, near-identical photos, screenshots, Live Photos, and large videos.
Sorting thousands of files manually wasn't practical, so I used Clever Cleaner. It separates duplicate and similar photos, duplicate videos, screenshots, Live Photos, and large media into categories. You can review files before removing them, shrink eligible photos with the Compress tool, or go through the library one item at a time in Swipe mode.
There's also Smart Cleanup, which handles similar photos and media compression across several categories in a few taps. The app is free, has no ads, and doesn't require a subscription to start using it. Some cleanup features have a fairly generous daily limit for new users.
This is the order I'd tackle everything:
  1. Clear out duplicates and similar photos.
  2. Check large videos and duplicate videos.
  3. Remove unwanted Live Photos, or compress them if you want to keep them.
  4. Delete screenshots you no longer need.
  5. Run Smart Cleanup if you want to deal with multiple categories together.
  6. Empty the Recently Deleted album. Otherwise, that storage may not become available for up to 30 days.
Messages can quietly take up a lot of space too. Deleting something from your Photos library doesn't necessarily remove the copy attached to a conversation. In Messages, open the conversation, tap the contact's name, then choose See All under Photos. From there, select and delete any attachments you don't need. Deleting an entire old conversation also removes its attachments.
If you use iCloud Photos, turn on Optimize iPhone Storage under Settings > Photos. That keeps smaller versions on the phone while storing the originals in iCloud.
It also helps to clean by event or album instead of scrolling through the full library. Going through 50 similar vacation pictures in one place is much quicker. After the initial cleanup, spending a minute or two each week removing new screenshots and duplicates can keep the problem from building up again.
There's usually no reason to wipe your whole photo library just to recover storage. Clearing duplicates, similar shots, oversized videos, unnecessary Live Photos, screenshots, and old Messages attachments can free up plenty of room without sacrificing important memories.
You can’t clear “photo data” as a separate cache without affecting the library. If iCloud Photos is enabled, deleting a picture on the iPhone deletes it from iCloud and other synced devices too. Export the keepers to a computer or another backup service first, confirm they open there, then delete unwanted items and empty Recently Deleted. If you want everything to remain in iCloud, use Optimize iPhone Storage instead of manually deleting synced photos.
Don’t keep deleting photos just because the storage number hasn’t changed yet. iOS can take a while to recalculate after you empty Recently Deleted, especially if the library is syncing with iCloud. Leave the phone on Wi-Fi and power, restart it, then check Settings > General > iPhone Storage later. Optimize iPhone Storage helps, but it may free space gradually rather than immediately, and only if your iCloud account has enough room for the originals.
Deleting more photos while the phone has virtually zero free space is often the wrong first move. iOS needs some working room to finish deletions, rebuild the Photos database, and replace originals with optimized copies. First remove a downloaded movie, offline music, podcast episodes, or offload a large unused app. Try to create a few gigabytes of breathing room without touching your photo library.
Then empty Recently Deleted and leave the iPhone charging on Wi-Fi for a while. If iCloud Photos is enabled, confirm your important pictures appear in iCloud or another verified backup before deleting anything. Avoid turning iCloud Photos off and back on as a cleanup trick, since that can trigger more downloading or leave you unsure which copies are stored where.
The Photos storage figure may include thumbnails and library database files, so it will not always drop immediately or match the size of what you deleted. Once syncing and processing finish, restart the phone and check iPhone Storage again.
Expect the storage number to lie to you for a while. Even after you empty Recently Deleted, the Photos figure in Settings can sit there unchanged for hours, and if you keep reacting to it by deleting more, you’ll end up cutting into stuff you wanted. @redgurux5329 and @silverlogic816 already nailed this, and honestly it’s the single most common mistake in these threads. The count is not real time.
Where I’d push back a little is on the idea that there’s no separate ‘photo data’ to clear. Technically true, but there is one hidden bucket people forget: the recovery period. When you delete, those files live in Recently Deleted for up to 30 days and still count against you the whole time. So if your phone is genuinely at zero free space, deleting alone does nothing until you empty that album. That part gets skipped constantly.
On the tool talk, Clever Cleaner is fine for the boring sorting work, duplicates and near identical bursts and screenshots. That’s the tedious part no human wants to do by hand. But it can only delete from the local library, so if iCloud Photos is on, anything you remove syncs out everywhere the same as @openpanda described. Treat it as a sorting assistant, not a magic vacuum, and verify your backup exists before you let any app batch delete.
My actual suggestion if you’re truly stuck at full: don’t start with photos at all. Free a couple of gigs somewhere painless first, an offloaded app or a downloaded show, so iOS has room to process. Then empty Recently Deleted, plug in, walk away, and check the next day. Nine times out of ten the number drops on its own and you never needed to delete the photos you were worried about.
One small annoyance nobody mentioned: shared albums and iCloud links don’t count against your storage the same way, so if you have a big family shared album, hunting through it for space is wasted effort.
