How To Turn Off Read Receipts On Android
I keep accidentally leaving people on read because my Android shows when I’ve opened their messages. I’ve dug through the settings but can’t figure out how to fully disable read receipts across my main messaging apps. Can someone walk me through the exact steps or point out what I’m missing so people stop seeing when I’ve read their texts?
Yeah, Android + read receipts is a minefield, because it depends on the app, not one single setting. Here is how to kill them in the main ones.
  1. Google Messages (blue chat bubbles / RCS)
    This is usually the main troublemaker.
• Open Google Messages
• Tap your profile icon in the top right
• Tap Messages settings
• Tap RCS chats
• Turn off:
  • Send read receipts
  • Show typing indicators
    • If you want to go nuclear, also turn off “Turn on RCS chats”. That forces plain SMS/MMS, which never send read receipts.
Note: If you use another SMS app as default, do the same kind of steps in that app. “Chat features” or “Advanced” is where it often hides.
  1. Samsung Messages
    If you are on a Samsung phone and use Samsung Messages instead of Google Messages:
• Open Messages
• Tap the 3 dots in the top right
• Settings
• Chat settings or Chat features
• Turn off:
  • Read receipts
    • If there is an option like “Rich communication” or “Chat features”, turn that off too.
If your carrier supports it, there might be a second read receipts toggle under “Text messages” or “Multimedia messages”. Turn those off as well.
  1. WhatsApp
    WhatsApp ignores Android’s system settings.
• Open WhatsApp
• Tap the 3 dots top right
• Settings
• Privacy
• Turn off “Read receipts”
Note: This also stops you from seeing others’ read receipts, and it does not disable receipts for group chats or voice notes. Those still show as read.
  1. Facebook Messenger
    • Open Messenger
    • Tap your profile picture top left
    • There is no true “read receipt” toggle here.
    • Only workaround is:
  • Turn on Notification previews in Android
  • Read messages from the notification shade, do not open the chat
  • Or put the phone in airplane mode, open chat, read, then close the app fully and turn airplane mode off. Clunky, but it works.
  1. Instagram DMs
    Same issue as Messenger.
There is no direct toggle. Workarounds:
• Use notification previews to read without opening the chat.
• Or the airplane mode trick:
  • Turn on airplane mode
  • Open IG, read the DM
  • Go back out of DMs
  • Force close the app from Recent Apps
  • Turn off airplane mode
    If you do not fully close the app before turning data back on, the “Seen” will often appear.
  1. Signal
    If you use Signal:
• Open Signal
• Settings
• Privacy
This one is clean. No weird side effects except you no longer see others’ reads.
  1. Telegram
    • Open Telegram
    • Tap the 3 lines or profile icon
    • Settings
    • Privacy and Security
Telegram does not offer a global read receipt toggle. Only workarounds are:
• Use “Last seen & online” controls to reduce visibility.
• Read messages from notifications.
• Use airplane mode + force close trick.
  1. Android system settings that help
    These do not disable read receipts, but help you avoid opening messages by mistake.
• Turn on notification previews:
  • Settings
  • Notifications
  • Allow content on lock screen and in status bar
    Then read as much as possible from notifications, not inside the apps.
• Disable “Bubbles” or “Chat heads” if they lead you to tap messages by accident:
  • Settings
  • Notifications
  • Bubbles (or similar)
  • Turn off for messaging apps you use.
  1. Quick checklist
If you want to stop read receipts everywhere you can control:
• Google Messages: RCS read receipts off, or RCS off
• Samsung Messages: Chat / RCS read receipts off
• WhatsApp: Privacy → Read receipts off
• Signal: Privacy → Read receipts off
• Messenger / Instagram / Telegram: use notifications or airplane mode trick
After you tweak each app, send a test chat to a friend or a second device. Check if your messages still show “Read”, “Seen”, the double blue checks, or similar. That is the easiest way to confirm what works for your specific phone and apps.
Couple of extra angles on top of what @sonhadordobosque already covered, especially if you want “as close as possible to OFF everywhere” instead of app‑by‑app whack‑a‑mole.
1. System‑level “behavior hacks”
Android doesn’t have a master “read receipt” switch, but you can rig your habits + settings to almost never trigger them:
A. Live in your notification shade
Turn on detailed previews so you can read most stuff without “opening” the chat.
  • Settings
  • Notifications
  • Lock screen / Notifications on lock screen
  • Set to “Show all notification content” or similar
Then:
  • Expand the message in the shade (swipe down again if needed)
  • Use “Reply” inline instead of tapping into the app when possible
Many apps only fire “Seen” when the conversation screen is focused, not when you just quick‑reply.
B. Split‑screen trick
If you do need to open a chat:
  1. Put some other app in split screen with your messenger (so the convo is partially off‑screen).
  2. Some apps delay or bug out on “Seen” when not fully focused.
  3. It’s inconsistent, but with Telegram / Messenger this sometimes stops instant “seen” spam.
Not perfect, but it reduces how often you fully open the chat by habit.
2. Alternative apps that respect your choice
If you’re flexible on what you use:
A. Use SMS‑only apps
If you kill RCS and just go pure SMS/MMS with a simple SMS app (e.g. some minimal SMS client), there are literally no read receipts at the protocol level. People only see “Delivered” at best.
This is more nuclear than what @sonhadordobosque suggested about RCS, but:
  • Turn off RCS in your current app
  • Switch to a dead‑simple SMS app with no “chat features” at all
Zero read receipts, ever, for regular texts.
B. Privacy‑first IM apps
You already saw Signal mentioned. Some others:
  • Threema and similar apps generally have explicit toggles for read receipts and are stricter about privacy.
  • Convince close friends / partners to move your “important chats” there where you actually control the setting.
For random group chats and acquaintances, accept that some apps just won’t play nice.
3. Specific app oddities people forget
Just a few bits that bite people even after they “turned stuff off”:
WhatsApp Web / Desktop
Even if you disable read receipts on your phone, these can still surprise people because:
  • Opening a chat on WhatsApp Web / Desktop can sync as “seen” very quickly.
  • Also, viewing statuses still shows you as a viewer by default; that is separate from message read receipts.
So if you use web/desktop, be strict: do not click into chats you want to keep “unread.”
Messenger & Instagram “seen” traps
Even outside the DM itself:
  • Opening the “Message requests” or “hidden” inbox and tapping something can trigger a seen.
  • Opening a shared thread from a notification tap instead of quick‑replying can insta‑flag “Seen,” even if you were just trying to scroll.
If you’re serious about stealth:
  • Disable “tap to open” from notifications for those apps by long‑pressing the notification and configuring its behavior, then rely on preview text only.
4. Social / expectation side (boring but real)
Tbh, even if you managed to kill 100% of read receipts:
  • People still infer “you saw it” from your Last Seen / Online status
  • Or from “you just posted a story / liked something” right after they messaged
So alongside the tech tweaks:
  • Turn down “last seen / activity status” in each app where possible
  • Tell a couple of main contacts: “I turned off read receipts everywhere. I reply when I can, not always instantly.”
That one sentence often does more for your stress than chasing every single toggle.
5. Reality check
You will not get a perfect “no app ever shows I saw anything” state unless you:
  • Only use SMS with RCS completely disabled
  • Or move all important convos to apps that truly respect read‑receipt toggles
Everything else is damage control plus habit changes: read in notifications, avoid tapping into threads casually, and use privacy‑friendly apps with the people who actually matter.
If you say what apps you’re on the most (and what phone), you can probably shave off a couple more “leaving people on read” traps specific to your setup.
