IPhone Running Slow For Weeks Now - Restart Doesn't Help, Any Ideas?
My iPhone has been running really slow for the past few weeks, and restarting it hasn’t fixed anything. Apps take forever to open, scrolling lags, and even simple tasks feel delayed. I need help figuring out what could be causing this and what I can do to speed it back up.
A slow iPhone has a weird feel to it. You tap, wait, then letters show up late. Scrolling looks choppy. Apps you used to open without thinking now sit there for 3 or 4 seconds. I’ve had it happen, and it’s annoying in a way people don’t get until their phone starts doing it too.
Is this an iOS bug
Sometimes no. If the slowdown started right after an iOS update, I’d wait before tearing the phone apart with random fixes. iOS does a bunch of cleanup work after a big update. It reindexes photos, rebuilds app data, and sorts system files in the background. While all this is going on, the phone feels off. Even simple stuff drags.
What worked for me was leaving the phone plugged in overnight on Wi-Fi for a few days. Three days felt like the minimum. In a lot of cases, the lag faded out on its own.
If you’re two weeks in, restarted a few times, and it still feels sluggish, then yeah, look elsewhere.
Storage is usually the first thing I check
This gets dismissed too often. Once free space drops into the last 10 to 20 percent, iPhones start acting cramped. Apps need scratch space to open and run. iOS needs room for temporary files. When there isn’t enough space left, the whole system starts dragging.
The symptoms match what people complain about most:
  • delayed keyboard input
  • stuttering when you scroll
  • slower app launches
  • random UI pauses
Deleting a couple apps usually didn’t fix it for me. The big storage leaks were almost always somewhere else. Long videos. Message junk. Thousands of screenshots. Ten versions of the same photo because I kept trying to get one decent shot and forgot to clean up later.
What fixed it for me
I tried sorting my library by hand once. Terrible idea. I had around 5,000 photos, and it turned into an hour of deleting three things, getting distracted, then giving up.
What ended up helping was Clever Cleaner. I expected the usual mess, ads everywhere, half the features locked, fake scan screen, all of it. This one was free in the plain sense. No ads. No subscription wall. No trick screen after the scan.
Here’s how I went through it.
  1. Open the Heavies tab first
This was the fastest win. It sorts your media from biggest file to smallest and shows the size on each item. My top results were a pile of 4K clips and old screen recordings I forgot existed. Deleting two or three of those gave me back several gigabytes fast.
  1. Then check Similars
This was the part I needed most. It grouped near-duplicate photos, not only exact duplicates. Stuff like five shots of the same meal, twelve blurry pet photos from one burst, small angle changes from the same scene. It picked a best shot for each group, and I cleared the extras in one pass.
  1. Look at Screenshots
This one hurt a little. I had so much trash in there. Delivery confirmations, random memes, Wi-Fi passwords, old maps, error messages I screenshotted to ‘deal with later.’ Every thumbnail shows file size, so it gets obvious fast how much space those are eating.
  1. Privacy looked fine to me
One thing I checked before using it was whether it uploads your photos. From what I saw, Clever Cleaner processes everything on-device. For personal photos, I cared about that.
After I cleared about 15GB and then emptied Recently Deleted in Photos, my phone stopped lagging. No joke, the difference was immediate.
Do not skip Recently Deleted
This part gets missed all the time. Deleting photos is only half the job. They sit in Recently Deleted for 30 days and still count against storage until you remove them for good.
Path is:
Settings is not where you do it. Go to Photos, Albums, Recently Deleted, then Delete All.
I skipped this once and wondered why my free space barely changed. Dumb mistake.
If storage looks fine
Then I’d check a few other things.
Battery health
Go to Settings, Battery, Battery Health. If maximum capacity is under 80 percent, performance throttling starts to enter the picture. iPhone does this to avoid shutdowns from an aging battery. If this is your issue, no setting tweak is going to fix it. Battery replacement is the fix.
Low Power Mode
If you leave Low Power Mode on all the time, turn it off and test the phone again. It cuts performance to save battery. Good for emergencies. Bad if you’re trying to figure out why the phone feels slow every day.
Background App Refresh
Go to Settings, General, Background App Refresh. I turned it off for apps that had no business doing stuff in the background. When too many apps are refreshing at once, the phone feels busier than it should. On an already struggling device, it adds up.
Keyboard lag only
If the keyboard is the main problem and the rest of the phone seems okay, reset the keyboard dictionary.
Go to:
Settings, General, Transfer or Reset iPhone, Reset, Reset Keyboard Dictionary
I didn’t expect much from this one, but it helped on an older device where typing delay had gotten bad.
Update your apps
Before getting too deep into diagnosis, open the App Store and hit Update All. I’ve seen post-iOS-update lag come from one or two outdated apps dragging everything down. An app built for the older version of iOS can behave badly enough to make the whole phone feel broken.
What I’d do in order
  1. Wait a few days after a major iOS update
  2. Check free storage
  3. Remove large videos, duplicate photos, and screenshot junk
  4. Empty Recently Deleted
  5. Update all apps
  6. Check battery health
  7. Turn off permanent Low Power Mode
  8. Reduce Background App Refresh
  9. Reset keyboard dictionary if typing lag is the main issue
For me, low storage was the whole story. Once I freed up enough space, the keyboard delay vanished, scrolling stopped stuttering, and apps opened like they used to. If your iPhone feels heavy and slow, I’d start there.
If a restart did nothing for weeks, I’d stop blaming random lag and check hardware and system load.
I agree with @mikeappsreviewer on storage first. That causes a ton of slowdowns. But if your free space looks fine, my next suspects are these:
  1. Battery health and overheating
    Old batteries slow iPhones down. Heat does too. If your phone feels warm doing simple stuff, something is chewing CPU in the background. Check Battery in Settings and look at which apps used the most battery in the last 24 hours and 10 days. If one app is way above the rest, delete it and test for a day.
  2. Safari bloat
    A stuffed Safari cache, tons of tabs, and ad-heavy sites make older iPhones feel awful. Clear Safari history and website data. Close the huge tab pile. People forget this one.
  3. VPN, antivirus, profile junk
    If you installed a VPN, ad blocker, security app, or a work profile, remove it for testing. I’ve seen those slow network calls and make apps seem broken when the issue was filterin traffic.
  4. Widget overload
    Too many home screen widgets and live widgets keep polling data. On older iPhones, the lag is noticeable. Remove most of them for a day and compare.
  5. Failing update install
    If the slowdown started after iOS and never improved, back up the phone and do a clean iOS reinstall through a Mac or PC. Not an erase-all as step one, but close. This fixes weird system corruption way more often than people think.
Also, if photos are eating space, Clever Cleaner is still worth a look for duplicates and large files. Different tool, same goal, free up room fast.
If you want a visual walkthrough, this step by step iPhone speed optimization guide covers the cleanup flow pretty well.
If you post your iPhone model, iOS version, free storage, and battery health %, people here will narrow it down fast.
I’d actually check one thing neither @mikeappsreviewer nor @viajeroceleste leaned on enough: accessibility settings and motion effects. Sounds random, but I’ve seen iPhones feel weirdly sluggish because stuff like Reduce Motion, excessive transparency effects, zoom filters, or Voice Control got toggled and started making the UI act off. Go through Settings > Accessibility and sanity-check anything you don’t remember enabling.
Another sneaky one is bad cellular performance being mistaken for a slow phone. If apps “open” slowly but mostly when loading content, reset network settings and test on strong Wi-Fi only for a bit. Same with iCloud sync. If Photos, Messages, or Files is stuck syncing a ton of data, the phone can feel busy all day.
I kinda disagree with the “just wait it out” advice if it’s already been weeks. At that point I’d look at analytics logs. Settings > Privacy & Security > Analytics & Improvements > Analytics Data. If you keep seeing the same app or process crash over and over, that’s your clue. Delete that app, or sign out of the related service and test.
Also, if you use your iPhone with basically no free space, then yeah, storage matters a lot. Clever Cleaner is useful for that, especially for duplicates, screenshots, and big videos. It’s also been listed among the top free iPhone cleaning apps here: best free iPhone cleaning apps for clearing storage fast
Last thing: if the lag happens system-wide, even in Settings, do a full encrypted backup and restore through Finder or iTunes. Not fun, but tbh that fixes deep cruft more often than people admit. If it’s still slow after a clean restore, then it’s probly battery/aging hardware, not software.
One angle I’d add beyond what @viajeroceleste, @yozora, and @mikeappsreviewer covered: check whether the slowdown is actually touch/display related, not raw performance.
A bad screen protector, failing digitizer zones, or touch sampling issues can feel like “lag” because taps don’t register cleanly and scrolling looks delayed. Easy test: remove the protector, clean the screen, then use Notes and Safari for 10 minutes. If it suddenly feels normal, that was the culprit.
Also check auto-brightness and True Tone weirdness. Sounds unrelated, but if the display is constantly adjusting and dropping brightness from heat, people often read that as the phone being slow.
One thing I slightly disagree on: not every weeks-long slowdown means full restore time yet. First boot into Low Power Mode off, Focus off, and with Notifications Summary disabled for a few hours. I’ve seen notification-heavy apps make older iPhones stutter all day.
If you need to free space fast, Clever Cleaner is fine for photo clutter.
  • quick duplicate/screenshot cleanup
  • easy way to find huge videos
  • simple UI
  • mainly useful if storage is the issue
  • less helpful for battery, thermal, or system corruption problems
  • photo review still needs human checking so you do not delete good shots
If lag happens even inside Settings, Camera, and app switcher while offline, that points more to battery/thermal aging or hardware than network/app junk. If lag is mostly inside specific apps, delete and reinstall only those apps first.
