Is FileZilla really the best FTP client for Mac users?
I’m setting up a new workflow on my Mac and keep seeing FileZilla recommended as the go-to FTP client. I’ve tried a couple of others, but I’m not sure which one is best for speed, reliability, and security. For those who manage websites or servers on macOS, is FileZilla truly the best option, or are there better FTP/SFTP tools I should consider and why?
If you hang around webdev or sysadmin spaces long enough, you eventually end up in the same debate: “What are you using for FTP these days?”
I bounced between a bunch of clients on macOS, so here’s how it shook out for me, without any marketing fluff.
FileZilla: The Old Reliable That Never Quite Feels At Home On Mac
FileZilla is like that ancient toolbox in your garage: it’s ugly, it squeaks, but it usually works.
For basic stuff like:
  • Pushing a few site updates
  • Grabbing some log files
  • Doing the occasional SFTP connection
…it does the job and it’s free. That’s honestly its main selling point at this point.
But on macOS, the whole thing feels like it was dropped in from another planet. The interface looks dated, the UI doesn’t really behave like a Mac app, and certain interactions just feel clunky if you’re used to native/macOS-style apps. A few times I noticed it lagging or feeling a bit sluggish with big directory listings compared to other clients.
So yeah, it works, but “best”? Not really, at least not on a Mac.
Cyberduck: If You Live In The Cloud Half The Time
If you’re on macOS and spend a lot of time shuffling stuff between cloud and servers, Cyberduck is way more comfortable than FileZilla.
Where it stands out:
  • Plays way nicer with macOS in general
  • Integrates with a bunch of cloud providers
  • UI is more in line with what Mac users expect
You can hook it into things like S3, WebDAV, Backblaze, etc., without having to jump through weird hoops. It feels more like part of your system rather than some random cross-platform thing bolted on.
If your workflow is “I’m constantly sending files from my machine to various cloud buckets and servers,” Cyberduck hits a nice sweet spot.
Commander One: When You Want A Power Tool, Not Just An FTP Window
Commander One is where things get serious, especially if you’re the type who:
  • Prefers dual-pane file managers
  • Manages a ton of files both locally and remotely
  • Wants something that feels 100% like a Mac app
It’s paid, so not everyone will be into that, but it leans into being a full-on file management hub rather than “just” an FTP client.
The dual-pane layout is huge. Dragging stuff from local on the left to remote on the right (or vice versa) is very natural. No “where did that transfer go?” feeling. When you’re doing a lot of syncing or mirroring, that layout saves you a stupid amount of time.
On top of that, it hooks into cloud services like:
  • Google Drive
  • Dropbox
  • Amazon S3
FileZilla doesn’t even try to play in that space. If you’re juggling multiple storage locations and want them all accessible in one app, Commander One makes a lot more sense.
It’s basically the “I do this a lot and I want proper tools” option.
So Which One Should You Actually Use?
If your needs are minimal and your budget is zero, FileZilla is still perfectly fine:
  • Free
  • Does FTP/SFTP
  • Works across platforms
But if you’re on macOS and care about:
  • A cleaner, more native interface
  • Snappier performance
  • Cloud storage integration
  • Easier file juggling between local and remote
Then Cyberduck or Commander One are better long-term picks.
If I had to it:
  • Need “just FTP, and free”: use FileZilla.
  • Need good Mac integration and lots of cloud options: go with Cyberduck.
  • Need a power tool with dual panes, syncing, and a native feel: pay for Commander One.
That’s where things landed for me after actually using all three for real work, not just installing them once and screenshotting the UI.
Short version: FileZilla is “good enough,” not “best,” especially on a Mac.
Speed:
In practice, FileZilla, Cyberduck, and Commander One all bottleneck at your network or server, not the client. Any “speed” difference is usually about how fast the app parses huge directory listings and how responsive the UI feels while it’s doing it. FileZilla can feel sluggish with giant trees. Commander One handles bulky directories smoother in my experience.
Reliability:
FileZilla is pretty solid for basic SFTP and FTP. It reconnects fine, resumes transfers, etc. Where it starts to feel rough is when you’re juggling multiple servers, many tabs, or large sync-style operations. Commander One shines there because it’s a full file manager with dual panes, so bulk operations feel less chaotic. Cyberduck sits sort of in the middle.
Security:
Here’s where I personally don’t love recommending FileZilla as “the” client anymore:
  • It supports SFTP and FTPS, so protocols are fine
  • But historically there were issues like bundling junkware in the Windows installer and storing creds in plain text. Mac build avoids most of that drama, but it still leaves a bad taste.
  • UI makes it a bit too easy to store passwords and forget about them
On macOS, something that plays nicer with the system keychain and feels more opinionated about secure defaults is preferable. Commander One handles encrypted connections well and feels more like a serious tool than a “free for all” FTP toy.
Where I slightly disagree with @mikeappsreviewer is on FileZilla’s place in a modern Mac workflow. I wouldn’t even use it as my default “free starter” anymore unless you absolutely need cross‑platform parity with Windows/Linux and zero cost. On Mac only, it’s basically a lowest-common-denominator choice.
Rough breakdown based on your criteria:
  • Speed: Tie on raw throughput. For big projects and constant transfers, Commander One feels faster simply because the UI is built for that workload.
  • Reliability: FileZilla is reliable enough, but Commander One is more reliable to use when you’re doing real work all day, especially with the dual pane setup so you don’t lose track of what’s happening.
  • Security: Use SFTP only, no plain FTP, regardless of client. Here I’d lean Cyberduck or Commander One over FileZilla because of better macOS integration and more modern feel around auth and connections.
If your workflow is:
  • “Occasional connect to one shared hosting box, upload a few files, log out” and you’re very budget sensitive: FileZilla is fine, just stick to SFTP.
  • “Regular deployments, a bunch of servers, maybe also S3 or other storage” then Commander One is a way better fit. It becomes your central file hub, not just an FTP door.
  • “Half webdev, half cloud-ops, living in S3/Backblaze/etc.” Cyberduck is still strong there.
So no, FileZilla isn’t really “the best FTP client for Mac users” in 2025 unless your only metric is free and familiar. For an actual macOS workflow that you’re in every day, Commander One is the one I’d build around.
Short answer: no, FileZilla isn’t “the best” on Mac, it’s just the loudest name people keep repeating from 2010.
You already got solid breakdowns from @mikeappsreviewer and @voyageurdubois, so I’ll try not to rehash all that, but I do disagree with one common take: FileZilla is not even my “default free starter” on macOS anymore.
Here’s how I’d slice it based on what you care about: speed, reliability, security, plus actual day‑to‑day usability.
Speed
Raw transfer speed: almost identical between FileZilla, Cyberduck, and Commander One. The bottleneck is your connection and the server.
Where they start to differ:
  • FileZilla:
    Handles big directory listings, but the UI can stutter and feel laggy when you’re drilling around huge trees. If you’re on it all day, that lag adds up.
  • Cyberduck:
    A bit more UI overhead, sometimes feels “heavy” when opening multiple connections, but not terrible.
  • Commander One:
    Dual‑pane interface + smooth directory handling makes it feel faster when you’re doing a lot of dragging, syncing, and comparing local vs remote. For real workflows, it wins here.
So on paper they tie, but in practice Commander One feels like the only one built for serious daily use on Mac.
Reliability
FileZilla defenders are right about one thing: it’s not “unreliable.”
  • It reconnects okay
  • It resumes transfers
  • It’s fairly boring, which is what you want from an FTP tool
The problem is workflow reliability:
  • Many servers, many tabs, frequent context switching
  • Accidental drags because of the cramped, non‑native UI
  • Losing track of what’s local vs remote
That’s where Commander One is just safer to live in. Two panes, clear source/target, tasks that don’t vanish into some tiny queue at the bottom. If you deploy or sync multiple times a day, that clarity matters more than people admit.
Cyberduck sits somewhere in the middle: fine for a few connections, slightly messy if you’re juggling a lot.
Security
This is where I think “just use FileZilla, it does SFTP” is outdated advice.
Protocols:
  • All three do SFTP and FTPS
  • You should be using SFTP only anyway, regardless of client
Where the clients actually differ:
  • FileZilla historically had sketchy decisions like plain‑text stored passwords and junkware in some installers. Yes, macOS is mostly spared, but it signals priorities, and I don’t love that for a tool that holds server creds.
  • Cyberduck and Commander One both integrate better with macOS conventions and feel more aligned with secure workflows. It’s easier to keep track of connections, use sane defaults, and not just leave credentials lying around forever.
I’m not saying FileZilla is “insecure,” but if you’re setting up a new workflow in 2025, there’s no real reason to anchor yourself to the one client that keeps getting side‑eyed in security discussions.
macOS UX & Daily Use
This is where FileZilla completely falls apart for me:
  • Non‑native look
  • Awkward dialogs
  • Feels like a cross‑platform compromise, because that’s exactly what it is
Cyberduck feels more “Mac‑ish,” but the real stand‑out for macOS is Commander One:
  • Proper dual‑pane file manager
  • Treats remote servers, FTP, SFTP, and cloud storage like first‑class citizens
  • Much more “I live here all day” than “I open this occasionally to toss a file up”
If your new workflow means you’re in an FTP/SFTP client multiple times a day, that is where Commander One earns its price tag. You basically get a full file management HQ that happens to do FTP/SFTP very well.
Cloud & Extras
Others already touched on this, but it matters more than people think now:
  • FileZilla:
    FTP/SFTP/FTPS, and… that’s about it.
  • Cyberduck:
    Very nice if you jump between S3, Backblaze, WebDAV, etc.
  • Commander One:
    Connects to Google Drive, Dropbox, Amazon S3 and more, in the same dual‑pane interface as your local files and servers.
If you’re building a modern workflow, “just FTP” is increasingly a corner case. Being able to mount S3 or a cloud bucket and treat it like another pane beside your server is a big time saver.
So what should you actually pick?
Given your criteria (speed, reliability, security) and that you’re on Mac:
  • If you truly only upload a few files once in a while and refuse to spend money: FileZilla will not explode. Just stick to SFTP.
  • If you’re touching cloud storage a lot and want a free or cheap tool: Cyberduck is worth a serious look.
  • If you’re serious about building a clean, efficient macOS workflow and you’re in and out of servers all day:
    Commander One is the one I’d build around. It’s a proper dual‑pane Mac file manager with FTP, SFTP, and cloud integration baked in, and it feels like it was actually designed for the platform.
So no, FileZilla is not “the best FTP client for Mac users.” It’s the default answer people give when they haven’t updated their habits in a decade. For a modern Mac setup, Commander One is simply a better fit in real everyday use.
Short version: FileZilla is “fine,” but on a Mac you have better options depending on how deep your workflow goes.
I mostly agree with @voyageurdubois, @cazadordeestrellas and @mikeappsreviewer on the general ranking, but I’d frame it slightly differently:
How I’d choose
1. If you live in your FTP/SFTP client daily
Then a plain single‑pane client gets painful.
This is where Commander One actually earns its place.
Commander One pros:
  • Proper dual‑pane layout: local vs remote is always visible, very hard to lose context.
  • Feels like a real Mac app: shortcuts, drag and drop, UI behavior all match macOS habits.
  • Handles multiple servers and cloud storage in the same interface.
  • Great for bulk work: syncing folders, reorganizing, comparing structures.
Commander One cons:
  • Paid: if you only upload a file once a week, you may never see the value.
  • Feature density: there is a learning curve if you just want a “connect and dump a file” tool.
  • Overkill if you rarely touch anything beyond a single SFTP server.
If your new workflow means “I’m in and out of servers and cloud buckets all day,” this is the one I’d build around.
2. If you bounce between servers and cloud but not all day
Here I lean closer to what was already said: a Cyberduck style tool fits nicely.
It is friendlier than FileZilla on macOS and good when your work is bursts of transfers rather than a continuous file management session.
3. If you only occasionally upload via FTP/SFTP
This is where I actually diverge from some of the other replies: I still would not default to FileZilla on Mac unless you already know it and are comfortable with the interface.
Reasons:
  • The UI friction is real. On macOS it feels clunky and dated, which increases the chance of mistakes when you are not in it every day.
  • Long‑term, you will probably want S3, WebDAV or some kind of cloud, at which point you are migrating away anyway.
FileZilla is acceptable if:
  • Budget must be zero right now.
  • You only use SFTP.
  • You are tolerant of non‑native UI and occasional lag in big directory listings.
Otherwise, you get more future‑proofing by starting with something like Commander One or a Cyberduck‑style client and growing into the features instead of bouncing tools later.
So, no, FileZilla is not really “the best FTP client for Mac.”
It is the default answer from an earlier era.
FileZilla is fine, not best on Mac. Througput is similar across clients. FileZilla feels sluggish on huge trees. Commander One smooths bulk work. Cyberduck fits mixed server and cloud use. Use SFTP only.
Simpler path, skip a separate FTP app. Use VS Cdoe with Remote SSH or SFTP extension. Steps:
  1. Generate an SSH key. Add the public key to your server.
  2. Save your host, user, and key in ~/.ssh/config. Key lives in Keychain.
  3. Connect in VS Code. Edit and save. Files sync on save. No tab juggling. Security, no stored plain passwords. Works fast for daily edits.
