My External Hard Drive Files Disappeared And I Have No Idea Why
My external hard drive was working fine, but when I plugged it in today, most of my files were gone and I have no idea what caused it. The drive still shows up on my computer, so I’m hoping the data is still there. I need help figuring out why files disappeared from my external hard drive and what I can do to recover them safely.
If Windows still sees the drive and gives it a normal letter, I’d take a little comfort from that. From what I’ve seen, it often points to a file system mess, broken folder records, or some other logical issue, not a drive that is flat-out dead. I had one do this with an old external HDD. Looked empty. Used space was still there. The files were recoverable.
What I would not do first is try to repair it.
Recover your files first. Worry about fixing the drive after.
A few things I’d avoid right away:
  1. Don’t format it, even if Windows throws up the format prompt.
  2. Don’t write anything new to the drive.
  3. Don’t run CHKDSK yet. I’ve seen it clean up the file system while also making recovery harder, since it rewrites parts of the structure you’re trying to pull data from.
Before you install anything or start scanning, check the easy stuff:
  1. Turn on Hidden items in File Explorer.
  2. Look at the drive’s used space. If the numbers still look close to what you expect, your data is often still sitting there.
  3. Swap the USB cable or move it to another port. Sounds dumb, but I’ve had a bad cable make a drive look half-broken.
If the files still don’t show up and there’s no backup, I’d move to recovery software.
I’d start with Disk Drill. I used it because the layout was simple and I didn’t need to guess my way through ten recovery modes. The part I liked most was disk imaging. If your external drive starts dropping offline, slowing to a crawl, or acting strange during reads, make an image first. That gives you a full copy of the drive at the sector level, then you scan the copy instead of hammering the original disk again and again.
This is the order I’d use:
  1. Install Disk Drill on your main internal drive, or on some other healthy disk. Don’t install it onto the problem drive.
  2. Launch it and pick the external drive with the missing files.
  3. If the drive feels unstable, make a disk image first with the built-in tool, then scan the image file.
  4. If the drive seems steady, hit Search for lost data.
  5. When it asks for scan type, pick Universal Scan. I’d do this almost every time. It rolls multiple recovery methods into one pass, deleted file search, damaged file system records, lost partition checks, and file signature detection.
  6. Let the scan finish. Large drives take a while. I know, it drags.
  7. Go through the results and preview a few files, especially the important ones. I always test a couple photos, docs, or videos before recovering a big batch.
  8. Save recovered files to a different drive. Never put them back on the same external disk during recovery.
On Windows, Disk Drill gives you up to 100 MB free recovery, which is enough to test whether your missing files are showing up before you spend money.
After your important files are safe, then I’d think about repair or a full reformat. If the drive keeps acting weird after that, I wouldn’t trust it again for anything important. I’d replace it.
One place where I’d stop the do-it-yourself route fast is suspected hardware failure. If the drive clicks, grinds, drops connection every few minutes, takes ages to respond, or vanishes from Windows, I’d unplug it and leave it alone. Software won’t fix failing hardware. More scans sometimes push a weak drive further downhill.
If the files matter a lot, family photos, work archives, old project folders, stuff you won’t get back, I’d skip home recovery and go to a pro data recovery service. Expensive, yep. Still the safer move when the drive itself looks sick.
If the drive still mounts and shows normal capacity, I’d check whether the files are missing or the file table is broken. Those are diff things. @mikeappsreviewer is right to avoid writing new data. I agree on skipping format. I’m a bit less strict on CHKDSK though. I use it only after I pull the important stuff off, never before.
A few extra checks I’d do first:
  1. Open Disk Management.
    See if the partition still shows the right size and file system. If it shows RAW, that points to corruption.
  2. Check SMART health.
    Use CrystalDiskInfo or the drive maker’s tool. If you see reallocated sectors, pending sectors, or read errors climbing, stop messing with the drive and copy data off fast.
  3. Try another computer.
    This rules out a bad USB controller, driver issue, or weird Windows profile problem. I’ve seen drives look empty on one PC and fine on another. Stupid, but it hapens.
  4. Look in Event Viewer.
    Windows Logs, System. Filter for Disk, Ntfs, Kernel-PnP. Repeated I/O errors tell you more than File Explorer does.
If the files are still gone, Disk Drill is a solid choice. I’d use it for an external drive data recovery pass, especially if you need to recover a corrupted hard drive and restore missing files from an external HDD. Scan first, preview files, then recover to a different disk.
Also, if your folders vanished after plugging into a TV, router, DVR, or Mac, check file naming and permissions. Some devices leave the disk in a messy state.
This might help too if you want a quick visual on how to recover files from a corrupted hard drive.
If used space still matches what you expect, your odds are usualy decent. If the drive clicks or disconnects, stop and go pro.
If the drive still mounts and shows the expected capacity, I’d also check whether this is a permissions/view issue before going deeper. Not everything that looks “deleted” is actually gone. I’ve seen Windows assign a different user context after an update, and suddenly folders look empty until ownership/permissions are fixed. So right click one of the top folders if you can still see any, check Security, and see if your account even has access.
I mostly agree with @mikeappsreviewer and @caminantenocturno about not writing to the drive. Where I slightly disagree is that people jump to software scans a bit too fast sometimes. First check whether the files were turned into shortcuts, especially if the drive was ever plugged into a public PC or sketchy machine. Malware loves doing that. Also run this in Command Prompt on the external drive letter:
attrib -h -r -s /s /d X:\*.*
Replace X with your drive letter. That can unhide stuff if the files were only marked hidden/system. Old trick, still works more often than ppl think.
Another thing, check the recycle bin with tools that show per-drive deleted items, and search the drive directly with wildcards like *.jpg or *.docx from the root. Sometimes the folder tree is broken but the files still index.
If basic checks fail, then yeah, Disk Drill is a solid next move for external hard drive data recovery, especially if the drive is visible but files disappeared. I’d use it to preview what’s recoverable before changing anything on the disk.
Also worth a read: real external hard drive data recovery success story
One warning nobody mentions enough: if this happened right after safely removing failed, power loss, or plugging into a TV, the folder structure may just be scrambled, not erased. Annoying, but fixable. If the drive starts clicking or freezing Explorer, stop messing with it becuase that’s when DIY turns into “why did I make it worse.”
