Need help finding the best data recovery software for Mac in 2026
I accidentally deleted important files from my Mac and emptied the Trash before realizing I still needed them. I’m trying to find the best data recovery software for Mac in 2026 that is safe, effective, and works well on the latest macOS. I need help choosing a reliable tool to recover documents, photos, and videos without making things worse.
I went through this a few weeks ago after I wiped an external SSD during a macOS reinstall. Dumb mistake. I tested a pile of recovery apps after that, and the one I kept coming back to was Disk Drill.
What sold me was the mix of results, speed, and a setup I did not have to fight with. A lot of Mac recovery tools look clean on the surface, then you run a scan and it drags for ages, previews fail, or APFS support feels half-done. Disk Drill handled modern Mac stuff better than most of what I tried. It ran fine on Apple Silicon, read APFS, HFS+, and exFAT without weird hiccups, and the recovery steps were plain enough that you do not need a sysadmin brain to get through it.
The preview part mattered more than I expected. Before paying, I opened docs, photos, videos, even PSDs, and checked if they were still usable. I saw other apps list thousands of “recoverable” files, then half of them were broken garbage. So this part saved me time.
A few extras stood out too:
  1. Byte-to-byte backup for unstable drives
  2. S.M.A.R.T. monitoring
  3. Duplicate cleaner
  4. Recovery Vault
  5. Advanced Camera Recovery for split up video files
The disk image feature is the one I’d keep around for. If your drive starts disconnecting, clicking, or doing random nonsense, making a clone first gives you a safer shot at pulling data off later.
If you’re dealing with harder cases, stuff like RAID, partition damage, or NAS recovery, R-Studio deserves a look. I get why IT people like it. It feels fast and low level. I would not hand it to a casual user though. The interface is dense, and if you are not used to filesystem tools, it gets old fast.
I also tried iBoysoft Data Recovery. It did better with APFS than I expected, so I’ll give it credit for that. My issue was the pricing. It kept leaning toward subscription stuff, and I’m kind of tired of software doing that for one-off jobs.
PhotoRec is still worth mentioning if free matters most. It works, sort of in the brute force way. You often get files back by signature, but filenames and folder layout are usually toast. On a big drive, the output turns into a mess fast. You spend a lot of time sorting through recovered junk to find what you need.
The bigger point, and this matters more than people think, is the app is only part of the story. What you do right after data loss matters more. On SSDs, especially, your odds drop fast if you keep using the Mac like nothing happened. New writes chew through old data quick.
If you lost something important, do this first:
  1. Stop using the drive
  2. Do not install recovery software onto the same drive
  3. Save recovered files to another drive
  4. If the drive is unstable, make an image before trying recovery
I learned this the hard way. Picking the “best” app matters less than not making the drive worse in the first ten minutes.
If you emptied Trash on a Mac, I would rank them like this for 2026.
  1. Disk Drill
  2. R-Studio
  3. PhotoRec
  4. iBoysoft
I agree with @mikeappsreviewer on Disk Drill, but I rate it higher for one simple reason. It fits normal people better. Fast scan times on APFS matter, but the bigger win is file sorting after the scan. If you deleted photos, docs, and project files, Disk Drill usually gives you a cleaner path to what you need. Less digging, less wasted time. That matters when you are trying to recover 20 files, not 200,000.
Where I disagree a bit, R-Studio is not only for IT people. If your data is worth a lot and you are willing to spend an hour learning the UI, it often pulls more from damaged volumes. It is ugly, but ugly software sometimes wins.
For a clean Mac recovery workflow, Disk Drill is the easiest pick. For broken partitions or nasty disk issues, R-Studio gets my vote. For free, PhotoRec still works, but the file names are often a train wreck.
One more thing. If your deleted files were on the internal SSD, recovery odds depend a lot on TRIM. On modern Macs, deleted blocks get wiped fast. So no app is magic there. If the files were on an external drive, your chances are way better.
If you want extra reading, this thread is useful for best Mac data recovery software picks in 2026:
best Mac data recovery software picks from Reddit users
Short version, try Disk Drill first. If it sees the files and previews them cleanly, you are in decent shape. If it does not, move to R-Studio. If the drive is making noises or dropping off the Mac, stop messsing with it and image it first.
If this happened on your Mac’s internal SSD, I’d be a little less optimistic than @mikeappsreviewer and @reveurdenuit. Not because they’re wrong, but because modern Macs + TRIM can make “best data recovery software for Mac” sound more magical than it really is. Sometimes the files are recoverable, sometimes they’re basically gone before you even finish panicking.
That said, for actual software, Disk Drill for Mac is still the first thing I’d try. Not just because it’s popular, but because it does a solid job showing you what is really recoverable instead of dumping a giant fake-hope file list in your lap. For recently deleted files on external drives, SD cards, and USB storage, it tends to be the least annoying option. R-Studio is stronger in some ugly edge cases, sure, but for normal people it can feel like doing taxes with a hex editor.
One small disagreement with the usual rankings: if your deleted files were mostly documents and office-type stuff, I’d also look at EaseUS Data Recovery Wizard for Mac before going straight to PhotoRec. PhotoRec is powerful, but the output is often a disorganized landfill. Useful, yes. Fun, no.
My short list for 2026 would be:
  1. Disk Drill for easiest overall Mac recovery
  2. R-Studio for damaged volumes / more advanced jobs
  3. EaseUS if you want another user-friendly option
  4. PhotoRec only if you’re patient and kinda desperate
Also worth checking if you want more comparisons: best Mac data recovery software for deleted files
If the files were on an external drive, your chances are way better. If it was the internal SSD… ehhh, maybe, maybe not. Mac recovery is annoyngly hit-or-miss now.
I’m mostly with @reveurdenuit, @nachtschatten, and @mikeappsreviewer, but I’d tweak the advice a bit: don’t judge Mac recovery tools only by scan results. On Mac, the preview quality and file structure recovery matter just as much, especially if you need specific project files instead of a giant pile of raw recoveries.
For 2026, Disk Drill is probably the best starting point for most people.
Pros of Disk Drill
  • Clean Mac interface
  • Good APFS and external drive support
  • Previews are usually reliable
  • Can sort results in a way that saves time
  • Includes extra tools like disk imaging and drive health features
Cons of Disk Drill
  • Not the cheapest option
  • Deep scans can still return lots of clutter
  • On internal SSDs with TRIM, it cannot perform miracles
  • Advanced users may find it less granular than R-Studio
Where I slightly disagree with the usual ranking is PhotoRec. Yes, it is free, but for Mac users who care about filenames and folder paths, it can be a headache. I’d honestly put it lower unless budget is the only factor.
My take:
  1. Disk Drill for easiest overall recovery
  2. R-Studio for tougher technical cases
  3. iBoysoft if you want another Mac-focused option
  4. PhotoRec for free, last-resort digging
If this was an external drive, your odds are decent. If it was the internal Mac SSD, software matters less than people want to admit. In that case, fast action matters more than brand choice.
