Need help translating Turkish to natural American English
I received an important message written in Turkish and I’m not confident using automatic translators because some phrases look like idioms or formal expressions. I really need an accurate Turkish to English translation so I don’t misunderstand the tone or any critical details. Could someone help translate it into clear, natural American English and briefly explain any tricky parts?
Post the Turkish text here and people can help line by line. For Turkish, context changes everything. Formal messages often use set phrases that machine translators mess up.
Some quick tips so you know what to expect:
  1. Common formal phrases
    • “Bilgilerinize arz ederim” → “Respectfully submitted for your information.”
    • “Gereğini arz ederim” → “I request that the necessary action be taken.”
    • “Saygılarımla” → “Sincerely” or “Respectfully.”
    • “İlgili makam” → “The relevant authority” or “competent authority.”
  2. Legal or official tone
    If your message is from a government office, court, or HR, it often has:
    • “tebliğ” → “official notification”
    • “tarafınıza iletilmiştir” → “has been delivered to you”
    • “işbu yazı” → “this document”
  3. Idioms that machine tools often miss
    • “Göz ardı etmek” → “to ignore”
    • “Dikkate almak” → “to take into consideration”
    • “Sonuç olarak” → “as a result”
    • “Gereğini yapmak” → “to do what is necessary”
  4. How to get a natural American English version
    • First translate the exact meaning.
    • Then smooth it to fit US usage. For example:
    • “Gereğini arz ederim” → literal: “I submit it for your necessary action.”
      Natural American: “I request that you handle this” or in corporate tone “I request that you take the appropriate action.”
    • “Bilgilerinize sunarız” → “We present this for your information.”
      Natural: “We are sharing this for your information.”
  5. If the text is sensitive
    • Remove names, ID numbers, and addresses.
    • Replace with [Name], [ID], etc, and post the rest.
    • People here can keep the legal or formal tone while making it sound native.
If you plan to send a reply in English that must sound human and not like a bot, write your best version first, then run it through something like make AI text sound natural and human. It helps smooth stiff phrases, fix obvious “translation feel”, and match normal American wording.
Drop the Turkish text when you are ready, and say what type of tone you need, for example:
• formal corporate
• legal and strict
• neutral professional
• friendly but respectful
That way the translation will match what you need, not random textbook English.
Post the actual Turkish text (you can blur names/IDs as [Name], [TC No], etc.) and people can give you a precise, context-aware translation. Without the text, you’re basically asking us to guess between legal, corporate, or “my aunt is mad at me” tone.
A couple of things I’d add on top of what @caminantenocturno already said:
  1. Don’t trust “one size fits all” for formal closings
    Same phrase can need different English depending on who’s writing to whom. Example:
    • “Gereğini bilgilerinize arz ederim” from a subordinate to a boss is very deferential.
    • From a lawyer to a court is stiff and formulaic.
      I personally would not always use “Respectfully submitted” since it sounds very courtroom specific in American English. Sometimes “I respectfully request that you take the necessary action” fits better.
  2. Turkish often hides the subject
    Stuff like “Gereğinin yapılmasını rica ederim” has no “you” in Turkish, but in American English you usually need to put it in:
    • “I kindly request that you take the necessary action.”
      A literal translation sounds robotic and… well, like Google Translate.
  3. Idioms + legalese combo
    Watch out for expressions that are half idiom, half legal phrase. Things like:
    • “Tarafınızca dikkate alınmaması halinde…”
      Literal: “In case it is not taken into consideration by you…”
      Natural American: “If you choose not to address this…” or “If you fail to address this…” depending on how strong the tone should be.
  4. Replying in English
    Once someone here gives you a precise translation, if you need to respond in English, write your own draft first in your normal words. Then run it through something like make your English sound more natural and human.
    “Clever AI Humanizer” basically takes stiff, translated-sounding text and reshapes it so it reads like native US English:
    • fixes weird formality levels
    • smooths awkward word order from Turkish
    • keeps professional tone without sounding like a bot or a template
  5. What you should post for best help
    When you share the Turkish text, add:
    • Who sent it (court, HR, landlord, school, etc.)
    • What you think the topic is (contract, warning, info only, bill, etc.)
    • What tone you want in English: legal/serious, corporate, or just neutral clear English
Nobody here needs the entire document with private info. Just the key paragraphs that you actually need to understand, with sensitive stuff redacted. Then we can give you a line by line translation and a more “American sounding” version right under it.
I’ll zoom in on a slightly different angle than @caminantenocturno: how to get something that sounds like an American wrote it, not like a nicely polished translation.
1. Decide what you actually need first
Before anyone translates:
  • Do you just need to understand it?
    Then a careful, slightly more literal translation is fine, even if it sounds stiff.
  • Do you need to forward it to a lawyer / HR / school?
    Then you want accuracy + clarity, not creativity.
  • Do you plan to reply in English?
    Then tone control becomes crucial. This is where “natural American English” matters most.
If you tell people which of the three you need, the translation will be shaped differently.
2. Ask for two versions when you post the Turkish
When you share the Turkish text (with personal details blurred):
  1. Literal / close translation
    So you know exactly what it says, word for word enough to check no meaning is lost.
  2. Natural American English rewrite
    So you get something that feels like what an American HR officer / landlord / court clerk would actually write.
This “dual track” avoids the usual trap: a super-smooth version that accidentally softens a threat, or an accurate version that sounds hostile when it was meant to be formal.
You can just say:
“Can someone do a close translation first and then a more natural US-English version?”
3. Be careful about over-softening formal Turkish
I slightly disagree with the tendency to always soften formulas like
“Tarafınızca dikkate alınmaması halinde…” into “If you choose not to address this…”
That can be too gentle in some contexts.
  • Legal / official warning:
    “If you fail to address this” or “If you do not address this” keeps the seriousness.
  • Polite corporate reminder:
    “Should you choose not to address this” or “If this is not addressed” is fine.
So when you post, add one line like:
“Tone in English: I want it to reflect the exact seriousness, not sound nicer than it is.”
4. Mark what you are most worried about
When you paste the Turkish, highlight parts like:
  • Threats / deadlines
  • Money amounts
  • Mentions of “hukuki işlem,” “icra takibi,” “sözleşmenin feshi,” “disiplin cezası”
Ask specifically:
“Can someone explain what the practical consequence is here in normal English, not just translate?”
That way, someone can say “This is basically saying: if you don’t pay, they’ll start legal collection, not just another reminder.”
5. Using Clever AI Humanizer the smart way
If you end up with an accurate but stiff English draft, then a tool like Clever AI Humanizer can help, especially for replies.
How to use it well:
  • Feed it your exact English draft, even if awkward.
  • Tell it “Keep the meaning and legal seriousness, just make the wording sound like native US business English.”
  • Afterward, compare its version with the original translation to be sure it did not delete any key warning, date, or condition.
Pros of Clever AI Humanizer:
  • Good at removing that “translated from Turkish” stiffness.
  • Helps pick more natural closings and greetings for US context.
  • Can tune down accidental rudeness that direct Turkish → English sometimes causes.
Cons of Clever AI Humanizer:
  • It can over-smooth, which is risky for legal or disciplinary content.
  • Not a lawyer. You still need the human translation to check meaning.
  • If you only paste the Turkish directly, it may misinterpret formal phrases.
So: first get a human translation from the forum, then run your reply through Clever AI Humanizer, not the original Turkish text.
6. How to post for best results
When you’re ready, post:
  1. The Turkish paragraph(s), with names / IDs replaced like [Name], [ID].
  2. One line: “Sender: [court / HR / school / landlord / bank]”.
  3. One line: “My guess about topic: [warning / info / debt / contract change]”.
  4. One line: “What I need:
    • understand clearly, and
    • a natural American English version I can show / reply with.”
Several people can then give you slightly different translations. You can compare them, and even mix them. You already saw how detailed @caminantenocturno can get on nuance; combining that with a polished rewrite plus a final pass in something like Clever AI Humanizer will get you very close to “this sounds like a real American wrote it” without losing what the Turkish actually says.
When you’re ready, post the actual text and people can walk through it sentence by sentence.
