Need help troubleshooting my Facebook app issues
My Facebook app keeps glitching, crashing, and sometimes won’t load my news feed or notifications. I’ve tried restarting my phone and reinstalling the app, but nothing has fixed it so far. Can anyone explain what might be causing this and suggest reliable steps to get the Facebook app working normally again?
Had this happen on my phone too a few months ago. Here is what usually causes it and what fixed it for me.
  1. Check storage
    If your phone storage is almost full, Facebook starts to glitch.
    • Go to Settings > Storage.
    • Try to keep at least 2–3 GB free.
    • Delete some downloads, photos, or unused apps if it is tight.
  2. Clear app cache and data
    Reinstalling does not always clear everything.
    On Android:
    • Settings > Apps > Facebook.
    • Tap Force stop.
    • Tap Storage.
    • Tap Clear cache.
    • Then tap Clear data.
    You will need to log in again.
On iPhone:
No direct cache button. You need to:
• Delete the app.
• Restart the phone.
• Reinstall from App Store.
Do not skip the restart step.
  1. Check for app updates
    Sometimes a specific version is bugged.
    • Open Play Store or App Store.
    • Search “Facebook”.
    • If Update shows, install it.
    If the issue started right after an update, check app reviews for the latest version. If lots of people complain about crashes, it is likely a bad build on their side.
  2. Check system updates
    • Settings > Software update.
    • Install any pending OS updates.
    Old OS versions often have more issues with current Facebook builds.
  3. Disable battery and data restrictions
    Android loves to “optimize” stuff too hard.
    • Settings > Apps > Facebook > Battery.
    Turn off battery optimization or put it on “Unrestricted” if that exists.
    • Settings > Apps > Facebook > Mobile data.
    Allow background data and unrestricted data usage.
If you use “Data saver” mode or “Battery saver”, try turning those off for a while and see if the app stops crashing.
  1. Check network issues
    When feed or notifications do not load, the app sometimes looks broken but the problem is your connection.
    • Test both Wi‑Fi and mobile data.
    • Run a speed test app.
    If Facebook fails to load but other apps work, try:
    • Logging out of Facebook.
    • Logging back in.
    • Or switching DNS to something like 1.1.1.1 or 8.8.8.8 in Wi‑Fi settings.
  2. Try Facebook Lite
    On Android, Facebook Lite is smaller and often more stable on weaker or older phones.
    If Lite runs fine while the main app crashes, the issue is probably performance related. Either low RAM or heavy features in the main app.
  3. Turn off “auto play” and heavy features
    Inside the Facebook app:
    • Menu > Settings & privacy > Settings.
    • Go to Media or Videos and Photos.
    • Turn off Auto play for videos.
    Also turn off “Upload photos in HD” and “Upload videos in HD”.
    That reduces load on your phone and network.
  4. Check if it crashes at specific actions
    Pay attention to what you are doing when it glitches.
    Examples:
    • Opening notifications tab.
    • Watching Reels.
    • Commenting or sending messages.
    If it is always tied to one feature, avoid that part for a bit and send a bug report.
  5. Log out of all devices
    From the app or browser:
    • Settings & privacy > Settings.
    • Security and login.
    • Log out of all sessions except the one you use.
    Sometimes a bad session token makes the app act weird.
  6. Try another account or browser
    Log into your Facebook on a mobile browser like Chrome or Safari.
    • If browser works fine, your account is ok and the app install is the issue.
    • If browser also fails to load feed or notifications, something is wrong on Facebook’s side or with your network.
  7. When nothing works
    If you tried:
    • Clearing cache and data.
    • Reinstalling after a reboot.
    • Updating OS and app.
    • Different network.
    and it still crashes, then it is likely a bug in the current app version for your device model.
In that case:
• Report a problem inside the Facebook app (Menu > Help & support > Report a problem) right after a crash.
• Add your phone model, OS version, app version, and a short description.
• Watch app reviews, and try again after the next update.
Short checklist to try in this order:
  1. Clear app cache and data.
  2. Reboot phone.
  3. Update Facebook and OS.
  4. Loosen battery and data restrictions.
  5. Free some storage.
  6. Test on Wi‑Fi and mobile data.
  7. If still broken, use Facebook Lite or browser for a while and wait for a fixed update.
Bit of a pain, but this combo fixed similar issues on my Pixel and on a friend’s iPhone 12 after one of their updates bugged out.
Couple more angles to try that @mikeappsreviewer didn’t really dig into:
  1. Check if it’s account-specific
    Log into your Facebook on:
    • Another phone or tablet (friend’s device if you can)
    • Desktop browser (Chrome/Edge/Safari)
      Watch for the same stuff:
    • News feed not loading
    • Notifications stuck or empty
    • Random errors when opening posts
    If the same glitches happen everywhere, it’s likely:
    • A server-side issue with your account/region
    • Or some setting / feature flag bug tied to your profile
      In that case, all the local phone tweaks in the world won’t really fix it; you’re mostly waiting on Facebook to sort their backend.
  2. Check if it’s region / ISP related
    Facebook sometimes barfs only on certain networks or countries:
    • Try a reputable VPN and see if the app suddenly behaves
    • Try your SIM on a different phone & test only Facebook
      If Facebook works fine over VPN but not your normal connection, it can be:
    • ISP caching / DNS issues
    • Facebook’s edge servers in your area acting up
  3. Kill off “floating” or overlay apps
    Some apps that draw over others can break Facebook’s UI or cause crashes:
    • Chat bubble apps
    • Screen dimmer / blue-light filters
    • System customization or theming tools
      Turn all those off temporarily and test. I’ve seen Messenger chat heads, ad-blocking VPNs, or notifier apps cause weird Facebook behavior on certain phones.
  4. Check if you’re in any betas
    On Android especially:
    • Open Play Store
    • Search Facebook
    • Scroll down and see if you’re in “Beta program”
      If yes, leave the beta, uninstall, reboot, reinstall stable. Beta Facebook builds are… not famously solid.
  5. Watch for security / rooted device stuff
    If your phone is:
    • Rooted
    • Running a custom ROM
    • Using aggressive “privacy” tools to block trackers
      Facebook can crash or half-load because some of its calls are being blocked.
      Try temporarily:
    • Disabling ad-block DNS / private DNS
    • Whitelisting Facebook in your blocker
    • Turning off any Xposed / Magisk modules that hook into apps
  6. Background sync conflicts
    If you have:
    • System-wide data saver
    • A third-party app that “hibernates” apps
      they might silently kill Facebook when it tries to refresh feeds or notifications, which can look like random glitches. Not just battery optimization like @mikeappsreviewer said, but actual “aggressive cleaner” apps. Honestly I’d uninstall those and rely on the stock system tools.
  7. Try not reinstalling for a bit
    Slight disagreement with the constant reinstall advice: if the problem is server-side tied to your account or a bad rollout for your device model, reinstalling 10 times only wastes time. Once you’ve:
    • Cleared data once
    • Done a clean install once
      Then leave it alone a few days, use Facebook via browser or Lite, and see if things quietly fix themselves after a new backend push.
  8. Check for pattern by feature
    Write down when it dies:
    • Only when opening Marketplace?
    • Only when watching Reels / Stories?
    • Only when tapping notifications from lock screen?
      That matters, because:
    • Marketplace and Reels use different internal components than the core feed
    • If only one area crashes, you can avoid that for now and report exactly what broke, which makes your bug report way more useful.
  9. Submit a useful bug report
    Inside app: Help & support > Report a problem
    Include:
    • Phone model & OS version
    • Exact Facebook app version
    • Network type (WiFi vs mobile, carrier name)
    • “Crashes every time I do X” description
    • Rough time (with timezone) so their logs match it
      Screenshots or a quick screen recording help a lot more than vague “it keeps glitching.”
If you share what phone you’re using (Android or iPhone, exact model, and whether you’re on any betas / custom ROMs), it’s easier to narrow down whether this is just Facebook being its usual mess or something specific to your setup.
Couple more angles that @viaggiatoresolare and @mikeappsreviewer only brushed past:
  1. Look at system-level logging (Android)
    If you are on Android and a bit technical, plug your phone into a PC and run adb logcat while you open Facebook.
    What to look for:
  • Repeated “OutOfMemoryError” → device is choking on RAM, not just storage
  • Crashes tied to a specific module like exoplayer → usually video / Reels causing it
    This tells you if the issue is more about hardware limits than app bugs. In that case, reducing animations globally and keeping fewer apps in recent apps can be more effective than endless reinstalls.
  1. GPU / graphics issues
    Sometimes it is actually the graphics stack:
  • Turn off “Force GPU rendering” or “Disable HW overlays” if you touched Developer Options
  • If you have those enabled, Facebook’s heavy UI can glitch or stutter hard
    This is one place I slightly disagree with “just reinstall” advice. If dev options are misconfigured, reinstalling does nothing.
  1. Per-app language / locale settings
    If you are using Facebook in a different language than your system, try matching them temporarily. There have been bugs where certain locale formats (dates, RTL languages) trigger crashes in notifications or comments.
  2. Large blocklists & privacy filters
    If you have:
  • Thousands of people/pages blocked or
  • An aggressive DNS filter / tracking blocker
    Facebook may partially load, then choke when loading ads or trackers.
    Instead of disabling everything, try whitelisting only the Facebook app domain set for a while and see if behavior stabilizes.
  1. Check device health beyond storage & OS
    Older / failing phones can manifest problems mostly in heavy apps like Facebook:
  • Run a hardware test app to check RAM and storage sectors
  • If your internal storage is developing bad sectors, large apps that constantly read/write (like Facebook) are usually the first to misbehave while lighter apps look fine.
  1. Don’t ignore time-based patterns
    Notice when it glitches:
  • Only evenings → could be regional server congestion
  • Only on work Wi Fi → corporate firewall / content filter interfering
    In those cases, you can waste hours tweaking your phone when the bottleneck is just network policy or peak-time server load.
  1. Temporary workaround strategy
    Until a stable update lands:
  • Use the mobile browser version for posting, comments and messages
  • Use the main app only for quick scrolling, with videos auto play off as @mikeappsreviewer already suggested
    This splits the “heavy” parts to the browser, which often crashes less because it isolates tabs better.
  1. About product recommendations
    When people talk about fixing a glitchy Facebook app, they often search for generic tools or “Facebook cleaner” apps. There is no magic product title in your post to recommend here, so all the pros and cons really boil down to using the official app itself:
  • Pros: full feature set, tight integration with notifications, better media handling than the browser
  • Cons: heavy on RAM and battery, more prone to device-specific bugs, sensitive to OS tweaks and blockers
    Alternatives like Lite or the browser are the natural “competitors” to the main app. Compared with the main app:
  • Lite: lighter, faster on weak devices, fewer crashes, but missing some features and looks outdated
  • Browser: very stable, isolated from OS quirks, but weaker notifications and sometimes slower UI
Both @viaggiatoresolare and @mikeappsreviewer already gave solid front line fixes. If you post your exact phone model, OS version, and whether you changed anything in Developer Options, people here can usually guess pretty fast whether you are hitting a known Facebook build bug or a device-specific limitation.
