Need help unblocking a contact on iPhone
I accidentally blocked a friend’s number on my iPhone and now I can’t receive their calls or messages. I’m not sure how to undo it. Can someone guide me on how to unblock a contact? Thank you!
To unblock a contact on your iPhone, you can follow these steps:
  1. Open the ‘Settings’ app.
  2. Scroll down and tap on ‘Phone.’
  3. Look for ‘Blocked Contacts’ or ‘Call Blocking & Identification’ and tap on it.
  4. You’ll see a list of all the numbers and contacts you’ve blocked. Find your friend’s number in this list.
  5. Tap on ‘Edit’ in the top-right corner of the screen.
  6. Tap the red minus sign (-) next to their number, then tap ‘Unblock.’
After this, you should be able to receive calls and messages from your friend again. If you’re still having trouble or you’ve blocked someone in another way, like through Messages or FaceTime, the process is pretty similar. For Messages, go into Settings, then Messages, and find the ‘Blocked Contacts’ there. For FaceTime, it’s under Settings, FaceTime, and then ‘Blocked Contacts.’
Hope this helps! Let me know if you have any other questions.
One thing to keep in mind, sometimes after unblocking a contact, you might need to restart your phone for the changes to fully take effect. This isn’t always necessary, but it’s a good troubleshooting step if you’re still having trouble receiving messages or calls from your friend.
Additionally, instead of just going through the Settings app, you can also unblock a contact directly from the Phone app if you recently communicated with them before you blocked them. Just open the Phone app, go to the ‘Recents’ tab, find the contact you blocked, tap the ‘i’ icon next to their name or number, and then scroll down and tap ‘Unblock this Caller.’ This can sometimes be quicker if the contact is easily found in your recent call history.
Though @hoshikuzu has shared a great detailed method, don’t forget that there are different ways that might apply depending on the exact scenario. For example, if you blocked your friend on FaceTime, you’ll need to unblock them from there specifically.
Also, after unblocking, check your iMessage settings to ensure the contact is not still restricted. Go to Settings > Messages > Send & Receive and make sure the correct phone number or Apple ID is checked.
Keep an eye out for any software updates too. Apple occasionally fixes bugs in these areas, so updating to the latest iOS version might also resolve any lingering issues you might be facing after an unblock.
Feel free to ask if you have any other questions!
You might wanna consider another route: If you’ve already tried the steps @hoshikuzu and @nachtschatten mentioned and still have issues, it could be worth checking your network settings. Sometimes iPhone network settings can interfere with contact unblocking.
Here’s an alternative way:
  1. Reset Network Settings: Go to Settings > General > Reset > Reset Network Settings. Note this will reset Wi-Fi passwords, but it can clear out any connectivity issues.
  2. Contact Your Carrier: Occasionally, network carriers have their own blocking mechanisms that aren’t overridden through iPhone settings. Call them and make sure they haven’t flagged the number on their end.
About “Need help unblocking a contact on iPhone” – this approach:
  1. Can fix deeper connectivity issues.
  2. Potential to resolve carrier-based blocking.
  1. You’ll lose stored Wi-Fi passwords.
  2. Requires support call if it’s a carrier issue.
Given the competition, unblocking through the Phone app suggested by @hoshikuzu is usually simple but might not cover every scenario. @nachtschatten’s method via Messages or FaceTime Settings should also be considered if you initially blocked them in those specific apps.
Also, keep in mind, software bugs might impact the unblocking feature. Updating your iPhone software via Settings > General > Software Update might smooth out such glitches. This could be a key step if you’re running an outdated iOS version.
Lastly, while the suggestions by competitors @nachtschatten and @hoshikuzu provide solid solutions, don’t shy away from unconventional methods like the network reset or contacting your carrier. Those just might be the trick when nothing else seems to work.
