Need help with new Oxzep7 Python software?
I just started using the new Oxzep7 Python software and ran into setup and compatibility issues I can’t figure out. It installed, but some features are not working like expected, and I need help troubleshooting the errors so I can get it running properly.
Start with the boring stuff, because Oxzep7 tends to fail on the same 4 things.
  1. Check Python version.
    Most builds of new tools like this break on 3.12 or older 3.8 installs. Try:
    python --version
    If you are on 3.10 or 3.11, that is often the safest spot.
  2. Use a clean venv.
    A dirty global install causes weird import errors.
    python -m venv .venv
    .venv\Scripts\activate
    pip install --upgrade pip setuptools wheel
    pip install oxzep7
  3. Verify deps.
    Run:
    pip show oxzep7
    pip check
    If pip check lists conflicts, fix those first. A lot of feature failures come from one bad dependency, not Oxzep7 itself.
  4. Test import directly.
    python -c ‘import oxzep7; print(oxzep7.version)’
    If this fails, post the full traceback. The exact error matters.
  5. If features fail but install works, check these:
    Missing system libs
    Wrong GPU or CUDA version
    Config file path issue
    Permission issue on cache or temp folders
    Python path pointing to a diffrenet interpreter than the one where you installed it
  6. Confirm interpreter path.
    which python
    which pip
    On Windows:
    where python
    where pip
    Those should point to the same env. If not, stuff gets messy fast.
  7. Try a minimal script.
    import oxzep7
    print(‘loaded’)
    Run it outside your main project. If this works, your project config is the issue.
  8. If there is a GUI or plugin piece, look at logs.
    A lot of new Python apps write logs under AppData, ~/.config, or a logs folder in the install dir. Check for import errors, JSON parse errors, or license/init failures.
Post these 5 things if you want a real fix:
Your OS
Python version
Oxzep7 version
Full error text
What feature breaks, and what you expected vs what happend
Without those, people will be guessing.
I’d add one angle that @suenodelbosque didn’t really lean on enough: sometimes the install is fine and the “broken feature” is actually an optional backend not being picked up.
A few things to check:
  • Run python -m pip list and see if Oxzep7 pulled in any extras you were supposed to install manually, like [gpu], [dev], [full], etc. A lot of packages quietly do that and then half the app looks busted.
  • Try python -X dev yourscript.py if it crashes during runtime. Dev mode can expose warnings that normal runs hide.
  • If Oxzep7 uses config files, rename the config folder and let it regenerate fresh defaults. Bad old config = weird behavior way more often than people think.
  • I kinda disagree that Python 3.10/3.11 is always the safe answer. Some newer libs are already targeting 3.11+ and behave oddly on 3.10, so check the project’s actual release notes if they exist.
  • On Windows, also test from plain cmd, not just VS Code terminal. IDE terminals lie sometimes, no joke.
If a feature specifically fails, say which one. Import works is one thing, but “export fails” vs “GPU accel missing” are totally diff problems. Post the traceback and maybe the package metadata from pip show -f oxzep7 too.
A slightly different angle from @suenodelbosque: verify you are running the Python interpreter you think you are. Oxzep7 Python software often “installs fine” into one environment while your shell, IDE, or task runner launches another. python -c 'import sys; print(sys.executable); print(sys.version)' and compare that with where pip installed the package.
Also check architecture mismatch. On Windows especially, 32-bit Python plus 64-bit native deps can make features silently fail instead of throwing a clean import error. Same story with Apple Silicon if a package component is still expecting x86_64.
If the problem is feature-specific, inspect optional system dependencies, not just Python ones:
  • where python or which python
  • python -m site
  • python -m pip check
  • python -m pip debug --verbose
pip check is underrated. It catches broken dependency resolution that still lets the package import.
Another thing I slightly disagree on with a lot of setup advice: reinstalling immediately is often wasted motion. Better to test in a brand new clean venv with one tiny script that reproduces the issue. If the tiny script works, your project stack is the problem, not Oxzep7 Python software itself.
Pros of Oxzep7 Python software:
  • usually quick to install
  • flexible if dependencies line up
  • good for scripted workflows
  • feature behavior can depend heavily on environment
  • optional native components may fail unclearly
  • IDEs can mask the real runtime state
If you post the exact error, OS, Python version, and whether the failing part is UI, export, plugin loading, or acceleration, the diagnosis gets way faster.
