Need help with the Upside app rewards and cashback
I’ve been using the Upside app for gas and groceries, but my recent purchases didn’t track correctly and I’m missing expected cashback rewards. I’ve double-checked my receipts and locations, and everything seems valid. Can someone explain what might cause Upside rewards not to appear and what steps I should take to fix this or contact support effectively
Upside is picky, so a few small things often break tracking. Run through this checklist.
  1. Check the offer timing
    • Make sure you “claimed” the offer before you pumped gas or paid for groceries.
    • Offers expire fast. If you filled up or shopped after the expiration time, no credit.
    • If you re-claimed at the same place, only the active claim counts.
  2. Match station and address
    • Open the Upside app, tap the location you used, confirm the address matches your receipt exactly.
    • Some chains have multiple listings in the app across the street or with slightly different names. Wrong one means no cashback.
    • If the station changed operators, the listing might be out of date.
  3. Payment method issues
    • For “check in” offers, your card must be listed in Upside before the purchase.
    • Prepaid, fleet, EBT, gift cards, and some corporate cards often do not track.
    • If you got a new card number but did not update the Upside payment list, it will fail silently.
  4. Receipt upload details
    • Make sure the entire receipt shows in the photo. Date, time, address, total, card type.
    • No shadows or blur over the merchant info or total.
    • If you paid inside after prepay on the pump, the preauth slip will not work. Use the final receipt.
    • Submit within the allowed time window from purchase. If you wait too long, they decline.
  5. Purchase requirements
    • Some gas offers exclude inside purchases, car wash, lottery, tobacco, gift cards.
    • Groceries offers often require “eligible items”. Alcohol, tobacco, lottery, or gift cards usually do not count.
    • Compare your receipt to the offer terms in the app.
  6. Duplicates and caps
    • If you stacked another cashback app or card-linked service at the same store, one system sometimes rejects the transaction.
    • Upside can limit the gallons or total amount. Extra gallons go unpaid.
  7. How to get support to fix it
    • In the app, go to Account > Help or Support > “Report a missing purchase” or similar.
    • Attach a clear photo of the receipt. If needed, send two photos: top and bottom.
    • In your message, include:
    • Store name and full address
    • Date and time
    • Payment method type (Visa, Mastercard, debit, etc)
    • That you claimed the offer before purchasing
      • Be direct: “Offer for [store name] on [date] did not track, here is my receipt, please credit manually.”
  8. What usually happens
    • When all data is clear, support tends to credit manually within a few days.
    • If they deny, they often reference the exact rule violated. Example, “offer expired,” “card not on file,” or “merchant not in our network.”
If you want, post the rough details here, like gas vs grocery, check in vs receipt upload, timing, and card type. People can tell you pretty fast where it broke.
I’ve had Upside bork a few “perfectly valid” purchases too, so you’re not crazy. A couple angles that weren’t really covered by @sonhadordobosque:
  1. Merchant ID weirdness
    Sometimes the address and brand are correct, but the underlying processor ID is different from what Upside has on file.
    • Example: Station got a new payment processor or franchise owner.
    • Result: Your receipt looks fine, app shows the place, but Upside doesn’t see it as the same merchant.
    Support can usually spot this if you ask specifically:
“Can you confirm if this location’s merchant ID matches what you have on file? It might’ve changed.”
  1. Partial approvals at the pump
    If the card is initially “preauthorized” for one amount and then adjusted, Upside sometimes only sees the ghost preauth, not the final sale.
    • This bites people who top off or who start/stop the pump multiple times.
    When you open a ticket, mention:
“Single completed transaction, total $X.XX, no multiple swipes.”
  1. Hidden limits on frequency
    Upside quietly tightens tracking if you hammer the same location or hit very high gallon amounts often. I’ve noticed that after a streak of big fill ups, one random transaction won’t track, then the next one is fine again.
    If this matches your pattern, ask support if your account hit any “rate limits” or “risk rules.” They won’t use those words, but you’ll see from their answer if that’s what happened.
  2. Account trust / fraud filters
    If you:
    • change phones often
    • use a VPN
    • log in from multiple devices in different states
    Upside’s system might flag your account. Instead of banning you, they’ll just stop auto-crediting a few purchases until a human reviews things.
    Mention in your ticket if you recently:
    • changed phone numbers
    • reinstalled the app
    • switched phones or re-logged in
  3. Double-check you’re not in “pending hell”
    Sometimes it is tracking, but stuck. Go to “History” and look for:
    • “Processing” or “Pending” older than 5–7 days
    Those are usually stuck in limbo. Ask support specifically to “review long-pending transactions on my account from [date range], they may be stuck in processing.”
  4. How I’ve gotten them to actually fix it
    What I’ve sent that worked more than once (copy-paste and tweak):
“Hi, I claimed an offer at [store + address] on [date/time]. I attached full receipt photos. Transaction total was $XX.XX for YY gallons. I used [card type], which is currently listed in my Upside wallet. The purchase is not showing in my history at all. Can you manually review and confirm whether this merchant is still correctly connected in your system and credit the cashback if eligible?”
If you want feedback before you contact support, post:
• Gas or grocery
• Check-in or receipt upload
• How long after purchase you submitted
• Whether the transaction shows as pending, declined, or not at all
From your description, my money’s on either a merchant ID change or some internal risk filter, not user error.
Couple extra angles to check that haven’t really been hit yet:
  1. Look at patterns, not single misses
    If multiple Upside app rewards / cashback hits in a row failed at different gas or grocery spots, that usually points to an account-level flag, not some minor user error. In that case, instead of “this purchase didn’t track,” message support like:
“Several recent offers across different locations have not tracked. Can you review my account for any flags or restrictions and confirm tracking is functioning?”
You’re asking them to fix the system, not just one transaction.
  1. Stop “testing” lots of small purchases
    I slightly disagree with the idea of just keeping on and letting them sort it out later. If you notice 1–2 in a row not tracking, stop doing additional test fills or grocery runs “to see if it works.” Upside’s risk system can interpret multiple small, closely spaced attempts as gaming behavior. Wait until support responds before running more claims at the same place.
  2. Avoid overly aggressive stacking
    Stacking Upside with card-linked services is fine in moderation, but I’ve seen accounts get weird when people hit: Upside + multiple card-linked offers + high-percentage store loyalty promos. Upside sometimes treats that pattern as high risk. To troubleshoot, do a “clean” test:
    • One regular credit/debit card
    • No other cashback apps activated
    • One modest fill or grocery run
    Then see if that one tracks. Mention this clean test in your ticket.
  3. Reinstall, but carefully
    Unpopular opinion: blindly reinstalling apps can make tracking worse if you change devices often. If you reinstall Upside:
    • Make sure you log in with the same email / phone as before
    • Verify your payment methods are still listed
    • Don’t use a VPN for the next few purchases
    After that, do one controlled purchase and watch if it shows as pending.
  4. Screenshot everything going forward
    From now on, every time you claim an offer:
    • Screenshot the claimed offer screen showing location, time, and cents-per-gallon or percentage
    • After purchase, screenshot the History tab for a few days
    If support drags their feet, attach these to your ticket and say:
“Here’s the claim confirmation and my history showing no transaction for that claim.”
That shortens the back-and-forth a lot.
  1. When contacting support, change the framing
    Instead of only “credit this transaction,” also ask:
“Can you tell me what specifically caused tracking to fail here so I can avoid it in the future?”
They sometimes reveal whether it was timing, card type, fraud rules, or merchant config. This is more useful long term than just one manual credit.
  1. Quick take on what others said
    @mike34 has a strong checklist that covers 80 percent of normal user mistakes.
    @sonhadordobosque dives more into the back-end quirks like merchant IDs and risk filters.
    I’d combine both approaches, then add the pattern-based view above so you can tell if the problem is you, the store, or your account profile.
Pros & cons of the Upside app in this context:
• Solid when it works: gas and grocery cashback can stack nicely with card rewards.
• Support does manually credit fairly often if you present clear proof.
• Wide coverage at many big-name stations and supermarket chains.
• Tracking feels brittle: small deviations in timing, card, or merchant setup can nuke rewards.
• Risk filters and merchant ID changes are totally opaque to users.
• Fixing issues costs you time, screenshots, and back-and-forth with support.
If you post your basics (gas vs grocery, check-in vs receipt upload, how many purchases in a row failed, and whether they show as pending or not at all), people here can usually tell if you’re dealing with a one-off glitch or an account-level issue before you even hear back from Upside.
Alternative, simpler path:
Stop using Apple Pay or Google Pay. Use the same physical card on file. Chip insert, no contactless, no PIN debit. Wallet tokens change the last 4, tracking fails often. Do two purchases only, 24 hours apart. One gas, one grocery. Claim, then take a single photo of each reciept. If both miss, send one ticket: “Both were chip with physical card, last 4 XXXX. No other apps active. Please sync my token and review merchant IDs.” This isolates wallet token issues fast. Many users report fix within 48 hours.
