I’ve been using QuillBot’s AI Checker on some blog posts and school papers to see if they look human-written, but I’m getting mixed results compared to other AI detectors. Sometimes it flags clearly human text as AI and misses obvious AI-generated content. Can anyone who’s tested it in depth share how accurate it really is, what its limits are, and whether it’s reliable enough to use for serious academic or SEO work?
I’ve played with QuillBot’s AI Checker quite a bit on blog posts, essays, and some random Reddit-style stuff I wrote.
Short version: it’s ok as a rough signal, but it’s not reliable if you need accuracy.
Here is what I noticed:
False positives on human text
- Personal essays and “chatty” blog posts sometimes get flagged as AI.
- Even my old college papers from before GPT existed got partial AI scores.
- It seems to dislike clean structure and repeated phrasing, even when that comes from a human.
False negatives on lightly edited AI text
- If you generate with GPT, then run it through QuillBot’s paraphraser or lightly rewrite sentences, the score often drops to “mostly human”.
- Short paragraphs with varied sentence length tend to pass more easily.
- Adding small grammar quirks, contractions, and a few typos helps it think it is human.
Sensitivity to length
- Very short texts swing a lot. A 150 word paragraph might be “highly likely AI”, but the full 1000 word article lands at “mixed”.
- I get more stable results on 500+ words.
Comparison with other detectors
Based on my testing with the same texts:- GPTZero and Originality.ai felt stricter and a bit more consistent.
- QuillBot’s checker sometimes contradicts them hard, like 80% AI vs 10% AI on the same input.
- When all three agree something is AI, they are often right. When QuillBot is the only one screaming “AI”, it is often a false alarm.
What this means for you
- Do not rely on it for serious academic or compliance checks. Teachers and editors who know this stuff will not treat it as proof.
- Treat the score as a hint, not a verdict.
- If you want to reduce AI flags:
• Add personal details, opinions, and specifics.
• Vary sentence length.
• Use first person and concrete examples.
• Leave a couple of harmless typos or slightly odd phrasing. - If it flags your human text, you can try:
• Adding more personal context.
• Breaking up repetitive sentence patterns.
• Reducing generic “textbook” style wording.
If you care about being judged as “human-written”
- Focus more on making your writing personal, specific, and slightly imperfect.
- Use multiple detectors if you want to see how risky a text looks.
- Assume all AI detectors have a lot of noise, including QuillBot’s.
So yeah, QuillBot’s checker works “ok” as a quick check, but it misses a lot and overflags a lot. I would not stake grades, jobs, or plagiarism disputes on its output.
Yeah, you’re not crazy, QuillBot’s AI Checker is kinda all over the place.
My experience lines up partly with what @hoshikuzu said, but I’m a bit less forgiving about it.
Here’s how it’s behaved for me:
It overflags anything that’s polished.
If you write like a halfway decent student or blogger, it starts screaming “AI” at chunks of your text. I’ve had old essays from ~2016 get tagged as “likely AI” just because they were structured and not full of fluff. That’s not “detecting AI,” that’s punishing competent writing. -
It underflags cleverly edited AI, but not always in a smart way.
If I take GPT text and change surface stuff (word choice, reorder a few sentences, add minor personal bits), QuillBot often relaxes the score a lot. But so do most detectors. Where it falls short is consistency. Sometimes literally the same AI paragraph with two swapped sentences suddenly becomes “mostly human.” That’s not nuanced detection, that’s volatility. -
The scores feel more like vibes than evidence.
The percentage looks precise, but it’s not. I’ve fed in:- 100% human text → anywhere from 10% to 90% “AI.”
- 100% AI text → sometimes 90% AI, sometimes “mixed” or even “likely human” after trivial edits.
Treat the meter like a mood ring, not a lab test.
QuillBot + other detectors together is the only semi-sane use.
Where I kinda disagree with @hoshikuzu is that I don’t think QuillBot is even “ok” as a standalone rough signal for anything serious. It’s better as a second opinion if you already ran something through GPTZero / Originality.ai and want to see if your text has that generic AI feel. When they all differ wildly, I’d personally trust the more established ones over QuillBot’s checker. -
It’s clearly tuned toward “better safe than sorry.”
That might sound good, but in academia that’s a nightmare. You do not want a tool that happily labels a careful human writer as suspicious just because they’re structured and coherent. I’d absolutely never let a teacher/admin use QuillBot as any kind of “proof” of AI usage.
If you’re trying to:
- Check your own stuff to see how “AI-ish” it might look: fine, QuillBot is a quick sanity check.
- Defend yourself, argue about plagiarism, or make decisions about students’ work: no, don’t even try. It’s way too noisy.
Tl;dr: use it like a weather forecast from a sketchy app. Maybe glance at it. Do not live your life by it.
