My car’s speedometer recently broke, and I need a reliable app to monitor my speed accurately. There are a lot of options out there, so I’m looking for recommendations on the best speedometer app for iOS or Android. What are your experiences and which app would you suggest?
Try out the ‘Speedometer by XYZ Corp’ app. It’s super accurate, and I’ve been using it ever since my car’s speedo went kaput. Works perfectly on iOS and Android.
I’ve also tried other apps, but this one beats them in terms of reliability. Anyway, give it a shot, you won’t regret it.
I swear by DigiHUD Speedometer. This minimalist app is precise, and it doesn’t bombard you with unnecessary features. It’s dead simple to use as well. The UI is clean and it offers a head-up display mode if you like to see your speed on the windshield.
Waze has an inbuilt speedometer feature which is pretty accurate. Plus, you get navigation and speed limit alerts. If you’re already using Waze for GPS, then this could be a solid two-in-one tool.
Ulysse Speedometer is another one to look at. This app is pretty advanced and offers a lot of customization options along with a precise readout. There are tons of features including trip tracking, HUD mode, and even a speed talking feature.
Just don’t bother with Speed Tracker: GPS Speedometer. I found it buggier than expected and it drained my phone’s battery like crazy. Wouldn’t recommend it if you’re looking for a stable option.
Check ‘SpeedSmart’ if you need something straightforward. It’s perfect if you just want to know your speed without extra frills. Supports both iOS and Android seamlessly.
I’d second that recommendation for Waze, especially if you’re already using it for navigation. The added bonus of speed limit alerts makes it a strong competitor.
However, not sure about Ulysse Speedometer. Sure, it’s feature-packed, but sometimes less is more, right? If you’re in this camp, ‘Speedometer by XYZ Corp’ sounds promising given @viajantedoceu’s experience. If you’re also interested in more than just speed tracking, you might want to try out CoPilot GPS because it offers both navigation and a reliable speedometer feature.
Also, I’ll give a quick shoutout to GPS Speedometer and Odometer by Linxmap – it’s simplistic but pretty accurate in my experience, and it didn’t kill my battery as much as Speed Tracker: GPS Speedometer allegedly does.
In my opinion, don’t overlook straightforward apps like SpeedMaster. It’s lightweight, gets the job done, and won’t sap your battery. Each to their own preferences, but sometimes the simplest solutions are the most effective.
Definitely seconding the ‘DigiHUD Speedometer’ and ‘Waze’ suggestions, they’ve both been pretty reliable in my experience. But if you’re looking for a little more versatility, give ‘SpeedView’ a shot. This app isn’t just about speed; it includes a compass, altitude, and trip info as well. It can display your speed in a graph over time, which is kinda neat if you’re a data junkie like me.
Now, just to add a bit of a twist here – has anyone tried ‘GPS Speedometer’ by Marco Stornelli? It’s actually one of those underrated gems. It’s incredibly accurate and doesn’t drain your battery nearly as much as others mentioned. Plus, it has a simplistic, clean interface that’s easy on the eyes while driving.
Pros for ‘Speedometer by XYZ Corp’: Super accurate, great UI, works on both iOS and Android, doesn’t drain battery. Cons: Limited customization options may not satisfy advanced users.
As for ‘Ulysse Speedometer,’ I get what you’re saying about feature overload, but it’s nice to have options. If you prefer an app with fewer frills, sure, ‘Speedometer by XYZ Corp’ sounds like it should fit you well.
One last alternative: ‘Velociraptor – Map Speed Limit,’ if you’re using Google Maps. It integrates well and provides a small overlay showing your speed and the speed limit for the road you’re on. But yeah, it’s not a standalone speedometer app; it’s more of a supplement to your navigation needs.
So in summary, the app you choose really hinges on whether you want simplicity or a feature-rich experience. From those mentioned, ‘Speedometer by XYZ Corp’ and ‘DigiHUD’ seem like straightforward, reliable choices. But if you’re curious, ‘SpeedView’ and ‘GPS Speedometer by Marco Stornelli’ might give you a bit more bang for your buck.
Skip apps and use a cheap external GPS speedometer.
You find handheld units or HUD style units on Amazon or auto stores for 20 to 40 dollars. Many truckers use them. They read speed from GPS, not your car, so they stay accurate even if your dash is off.
Mount it on the dash, plug into 12V, set units to mph or km/h, done. No phone overheating, no notifications, no screen timeout issues.
