Why is my SD card not being read by my Mac?
I’m trying to access my SD card on my Mac, but it’s not showing up. I’ve tried different SD cards and ports, but nothing seems to work. I need to transfer some important files. Any suggestions?
It’s frustrating when your SD card isn’t being recognized by your Mac, especially when you have important files to transfer. Here are a few things you can try:
  1. Check Finder Preferences: Make sure that external disks are selected to show on the desktop. You can do this by opening Finder, then going to Preferences, and selecting the General tab. Ensure ‘External disks’ boxes are checked in both the General and Sidebar tabs.
  2. Disk Utility: Sometimes, the SD card won’t show up on the desktop but will appear in Disk Utility. Go to Applications > Utilities > Disk Utility and see if your SD card appears there. If it does, try running First Aid to repair any issues.
  3. Terminal Commands: Open the Terminal application (Applications > Utilities > Terminal) and type diskutil list to see if the SD card shows up in the list of connected devices. This will help you determine if the Mac is recognizing the card at all.
  4. Reboot: Restart your Mac. Sometimes a simple restart can resolve recognition issues.
  5. Another Card Reader: If your Mac still doesn’t recognize the SD card, try using an external USB SD card reader. Your built-in card reader may have developed a fault.
  6. Potential Corruption: If the above steps don’t work, your SD card may be corrupted. In this case, consider using software like Disk Drill for Mac to recover and access your files. It’s a robust tool that can help you retrieve data from corrupted SD cards.
  7. Format SD Card: If you’re able to access the card through Disk Utility but can’t open the files, consider backing up any accessible data and then reformatting the card.
For more detailed steps on how to recover a corrupted SD card using your Mac, click on this helpful article: how to recover a corrupted SD card using your Mac.
Hope one of these suggestions works for you!
Hey,
Let’s get your Mac to read that SD card! Looks like @chasseurdetoiles covered a lot of good ground. Just to add a little more depth from my side:
  • Inspect the SD card physically: Sometimes simple things are the issue. Check if the metal contacts on the SD card have dirt or dust. A simple blow or a light sweep with a dry, lint-free cloth can sometimes work wonders.
  • Reset the PRAM/NVRAM: This is a bit deeper tech tip but resetting the PRAM/NVRAM can resolve some of these recognition issues. Restart your Mac and hold down Option + Command + P + R for about 20 seconds.
  • Safe Mode Boot: Sometimes booting your Mac in Safe Mode can help diagnose and fix issues. Restart your Mac and hold the Shift key until the Apple logo appears.
  • System Report Check: Go to About This Mac > System Report > Hardware > Card Reader. If the SD card reader shows up there, but the SD card still isn’t being recognized, it’s likely the card and not the reader.
  • Software Issues: Sometimes, your macOS might be the issue. Make sure your OS is updated to the latest version. Occasionally, software bugs can cause these issues, and Apple usually patches them in updates.
Don’t forget that “Disk Drill for Mac” is a powerful tool. It can recover and access files from corrupted SD cards. If you’re seeing the SD card in Disk Utility but can’t access the files, this might be a good time to invest in recovery software.
For more tips, check out this reddit discussion on SD card recovery programs. The community there always has some great insights.
Hope you figure it out!
